A reference on known problems can not find it.Karba wrote:Problem is If you do mistake in some words google translator can't translate it properly.pyrnik wrote:We're testing the product, not just obschaemsya.Chem more if I write about any issue, using an interpreter, the meaning may be distorted and loss. Can someone too lazy to use a translator. I suggest you tie a forum automatic translation of the Russian, so if I write in the text box text when sending to the server so that it automatically translated.
Так лучше?
We have a special topic.
http://render.otoy.com/forum/viewforum.php?f=39
You can use Russian there. I read it sometimes.
I once wrote about the problem of memory overflow, then this problem fixed. In my opinion the problem came back to this version of the plugin.
(Also very often flies 3d max when closing or updating the viewport)
maybe this is better?
