Version 4 - XB3-R1 (Experimental)
Forums: Version 4 - XB3-R1 (Experimental)
Moderator: aoktar
Postby aoktar » Thu Jun 14, 2018 9:25 am
aoktar Thu Jun 14, 2018 9:25 am
Hi All,
This is next test/preview release of plugin which is based on V4-XB3 SDK. We recommend that you mention that it is experimental, they should not use it for production work, and that we cannot guarantee backward compatibility.
Please see this thread for V4 features: viewtopic.php?f=33&t=66013
Standalone V4 XB3: viewtopic.php?f=33&t=67790
Important notes:
Since XB2 Preview, we have dropped support for Fermi cards.
Network render is still disabled.
Denoiser does not denoise volumes or hairs yet.
Denoiser is under Camera Imager from Settings or Camera Tags. Just denoised beauty pass is available in plugin, others will be added.
Changes of V4-XB3
- Help support for the Nodes in Node Editor
- Geometry Engine default changed to "All Movable"
- Visualisation for VDB voxels
Changes of V4-XB2.1 test2
- Fixed random material preview crashes, mostly on LiveDb
- Fix: error on OSX and reading of ScatterObject/csv files
- Added: New universal material to Octane Material and Blend material
- New options in Instance Color and XP emitter
Addons for plugin side
- Viewport rendering: Activate from Live Viewer/Octane dialog options menu. Keep open the one of these windows during the render session.
- Node Editor: Experimental float sliders on nodes. Need to activate from "settings->nodes->embedded gui".
- Node Editor: Show/hide options for node pins.
- New help system, updated manual(it's still wip). Access by help icons from nodes/etc..
- Several minor fixes.
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... R1-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Re: Version 4 - XB3-R1 (Experimental)
Postby caexsar » Thu Jun 14, 2018 11:54 am
caexsar Thu Jun 14, 2018 11:54 am
first of all tx a lot for this release ..
It seems that WINDOWS SUBSCRIPTION(Studio) BUILD has MAC file linked to download.
Cheers
Cesare
caexsar
Postby sbstnc » Thu Jun 14, 2018 12:57 pm
sbstnc Thu Jun 14, 2018 12:57 pm
Awesome times, thanks for your continued work on the XP builds!
When may we see netrender back in the equation please?
Cheers
sbstnc
Postby omardex » Thu Jun 14, 2018 10:30 pm
omardex Thu Jun 14, 2018 10:30 pm
Greetings I have this bump that I cannot render to Picture Viewer an old v3.08 scene in this version (XB3 R1), Live viewer renders fine. the picture viewer stays at 0.013% in the octane lower status bar
Version XB2.1 (Test2) renders perfectly the same scene and all the passes without issue and without apparent visual differences.
Sadly I cannot share the scene, but I'm sharing screenshots from the Pv and the console in case any errors pops up
This one is the XB3-R1 the render doesnt move
This one is XB2.1 (Test2) no issues
Any thoughts?
Thanks.
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
omardex
Postby aoktar » Thu Jun 14, 2018 10:53 pm
aoktar Thu Jun 14, 2018 10:53 pm
omardex wrote:Greetings I have this bump that I cannot render to Picture Viewer an old v3.08 scene in this version (XB3 R1), Live viewer renders fine. the picture viewer stays at 0.013% in the octane lower status bar
Any thoughts?
Thanks.
I think it's about a bug on gpu manager of plugin. It looks like stoped due don't have any gpu on rendering.
Postby omardex » Thu Jun 14, 2018 10:57 pm
omardex Thu Jun 14, 2018 10:57 pm
Thanks Aoktar.
Omar Tavera
Awesome Generalist
omardex
Postby haze » Fri Jun 15, 2018 2:21 am
haze Fri Jun 15, 2018 2:21 am
sbstnc wrote:Awesome times, thanks for your continued work on the XP builds!
Cheers
Our intention was to have net render for XB4, but this is looking unlikely now. At the moment, it could be XB5, but we'll have more detail on this soon.
haze
Postby agnes_io » Fri Jun 15, 2018 5:23 am
agnes_io Fri Jun 15, 2018 5:23 am
Any thoughts?
Thanks.
I'm having this same issue. Just hangs after the first few samples are rendered. Renders fine in Live Viewer.
agnes_io
Postby aoktar » Fri Jun 15, 2018 6:35 am
aoktar Fri Jun 15, 2018 6:35 am
agnes_io wrote:I'm having this same issue. Just hangs after the first few samples are rendered. Renders fine in Live Viewer.
I've made a quick fix for this issue. It was a problem on Windows version. Please re-download and install it again.
Postby milanm » Fri Jun 15, 2018 2:27 pm
milanm Fri Jun 15, 2018 2:27 pm
Ahmet, OSL is running super smooth in this version! I have been using (and abusing) Raytype script all day and not one hiccup so far. Great work!
Now we just need that UI for projection pins and we're complete. I have a few more scripts I have been preparing to port over.
Regards
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
milanm
Next
Return to Releases
Who is online
Users browsing this forum: No registered users and 5 guests
Thu May 09, 2024 7:01 pm [ UTC ]
