Thanks for feedback
Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Not yet, technically Octane 2020.1.5 is based on v8 SDK, while OctaneX is based on v10 SDK, so we need some more development before they will be both on the same SDK level for Network rendering.nibbler wrote:Is Multi-Platform Network Rendering with 2020.1.5 Clients and Octane X Master allready integrated?
Thanks for feedback
Stay tuned!
ciao Beppe
Read first post.bottom wrote:Hi there,
Does the latest version work in C4d R23?
Many thanks
Stuart
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Published the new builds(R4) over R3.
Changes of 2020.1.5-R4 plugin
- Matrix object support with Scatter Object
- More motion blur accuracy on export orbx, support for "time sampling per frames" parameter
- Hide/Show option for LV icons
1.When will Neutron (node-based sys) be supported R23?aoktar wrote:Published the new builds(R4) over R3.
2.When will C4D XB 2020.2 ?
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
thanks for udpdate,
just to point out that there are 2 "Reset" slots in the new menu.
And also can you tell us about the functions of the "Octane Menu" and "Octane Icons" slots of this new menu, because here so far, they don't seem to have any effect ?
thanks for udpdate,
pxlntwrk.net
pxlntwrk.net
- eyeonestudio
- Contact:
S22 : File Menu - String Not Found
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Hi Ahmet, i found a new bug, please take a look.
https://yadi.sk/i/BUeetDn2PRDkIw
I also noticed that in some cases octane cannot exit solo mode material. Nothing helps. We have to restore scenes from a backup. And if there is no copy, then the whole work will be ruined.
