Getting Textures from a material
Forums: Getting Textures from a material
Postby MB » Fri May 27, 2016 10:49 pm
MB Fri May 27, 2016 10:49 pm
I have the following situation illustrated at end of post.
I am successfully looping through the material pins on a mesh node, identifying there type and getting some information. I was surprised I did not need to do anything specific to tell octane to look for external materials nodes connected to a pin. However I cannot seem to get to the texture file information from any node. Can someone please point me in the right direction. Current routine is included below.
--if node type is glossy
if internalMatNode.type == octane.NT_MAT_GLOSSY then
print (" ")
print("Glossy Material")
print ("----------------------------------")
-- get the diffuse pin values
tblDiffuseValues = internalMatNode:getPinValue(octane.P_DIFFUSE)
print ("Diffuse Pin Values For: " ..internalMatNode.name)
for k, v in pairs(tblDiffuseValues) do
print(k, v)
end
-- if pin has an image, get image file name
-- first determine if another node is attatched
local inputNodeA =internalMatNode:getConnectedNode(octane.P_DIFFUSE)
print ("Glossy input a",inputnodeA)
local inputNodeB =internalMatNode:getConnectedNodeIx(pinIx)
print ("Glossy input b",inputnodeB)
local inputNodeC =internalMatNode:getInputNode(octane.P_SPECULAR)
print ("Glossy input c",inputnodeC)
local inputNodeD =internalMatNode:getInputNodeIx(pinIx)
print ("Glossy input d",inputnodeD)
local inputNodeE =internalMatNode:getOwnedItemIx(pinIx)
print ("Glossy input e",inputnodeE)
local inputNodes =internalMatNode:getInputNodes()
for k, v in pairs(inputNodes) do
print(k, v)
end
-- get the specular pin values
tblSpecularValues = internalMatNode:getPinValue(octane.P_SPECULAR)
print ("Specular Pin Values For: " ..internalMatNode.name)
for k, v in pairs( tblSpecularValues) do
print(k, v)
end
-- if pin has an image, get image file name, check if pin has an inputnode
-- get the opacity pin values
tblOpacityValues = internalMatNode:getPinValue(octane.P_OPACITY)
print ("Opacity Pin Values For: " ..internalMatNode.name)
for k, v in pairs(tblOpacityValues) do
print(k, v)
end
-- get the Normal pin values
tblNormalValues = internalMatNode:getPinValue(octane.P_NORMAL)
print ("Normal Pin Values For: " ..internalMatNode.name)
for k, v in pairs(tblNormalValues) do
print(k, v)
end
-- get the Bump pin values
tblBumpValues = internalMatNode:getPinValue(octane.P_BUMP)
print ("Bump Pin Values For: " ..internalMatNode.name)
for k, v in pairs(tblBumpValues) do
print(k, v)
end
end
thx
mark
Windows 7 Enterprise, 2x Intel Xeon X5650 2.66 GHz, 24GB Ram, GTX 590, Quadro 5000, Quadro K4200
MB
Re: Getting Textures from a material
Postby MB » Sun May 29, 2016 3:41 am
MB Sun May 29, 2016 3:41 am
After several hours I seem to have this working, so no help required at the moment.
MB
Postby roeland » Mon May 30, 2016 2:11 am
roeland Mon May 30, 2016 2:11 am
For reference this is how you can find out the filename of the image texture used by the material:
Assume we have a material node matNode:
-- get the node connected to the diffuse pin (skipping linker nodes)
local texNode = matNode:getInputNode("diffuse")
-- assuming T is an image texture node:
local filename = texNode:getAttribute("filename")
By default the diffuse input will have an RGB colour. In that case getPinValue can get the colour directly:
-- now, assuming we have an RGB colour node:
local rgbColour = matNode:getPinValue("diffuse")
Roeland
roeland
Postby MB » Wed Jun 01, 2016 10:15 pm
MB Wed Jun 01, 2016 10:15 pm
Roeland,
I wondered when you have a moment if you could explain in more detail the difference between getConnectedNode and getInputNode.
thx
mark
MB
Postby roeland » Thu Jun 02, 2016 10:06 pm
roeland Thu Jun 02, 2016 10:06 pm
  • getConnectedNode gives you the node directly connected to an input pin. This may be an input or output node of a graph.
  • getInputNode automatically skips linker nodes
So suppose for instance if you use a liveDB material (which will imported as a node graph) and connect it to a mesh. If you call getConnectedNode it will return the output linker node of that nodegraph. getInputNode returns the actual material node inside the node graph.
Roeland
roeland
Return to Lua Scripting
Wed Aug 05, 2020 5:13 am [ UTC ]
