you should put a layer of geometry (with water shader) that covers the entire eyeball/tearduct which extends onto the the thickness of the eyelid. almost like shrink wrapping the entire eye. that right eyeball feels like it's just stuck into the eyelid because of this missing. small detail but it helps the eyes alot. Great looking work!
http://img04.deviantart.net/5abc/i/2006 ... k_cube.png
Emily
- itsallgoode9
- Contact:
Thanks for your comments.
Yes i use mixed specular and diffuse shaders for the SSS, themselves mixed with a glossy shader. Here is a capture of my node editor. I'm on Cinema 4D R14.Jolbertoquini wrote:It's looking Really nice I start make again I was think the advise they propose just doesn't work with Octane I try but is really weird result I guess I will use more specular shader is what you use on this scene??
You are right, the eyes i've made are not well. My goal was to better understand the SSS and skin. I did not want to change the supplied mesh. I will try to focus on the eyes a next time.itsallgoode9 wrote:you should put a layer of geometry (with water shader) that covers the entire eyeball/tearduct which extends onto the the thickness of the eyelid. almost like shrink wrapping the entire eye. that right eyeball feels like it's just stuck into the eyelid because of this missing. small detail but it helps the eyes alot. Great looking work!
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
- Antoncromas
This is a pretty old topic. . . But can anyone share the modded maps again please? The links are broken.
Thanks.
Thanks.
Antoncromas wrote:This is a pretty old topic. . . But can anyone share the modded maps again please? The links are broken.
Thanks.
I believe everything is still there> http://gl.ict.usc.edu/Research/DigitalEmily2/
all links are at the bottom of the page
pxlntwrk.net
pxlntwrk.net
- Antoncromas
Thanks, but thats not what i was looking for, i got those =)pxlntwrk wrote:Antoncromas wrote:This is a pretty old topic. . . But can anyone share the modded maps again please? The links are broken.
Thanks.
There were links to edited eye textures by someone from the community.
