SASHA-16 (V4 with Weight Mapping) & Subdivision Issue
This is a strange one.  I made a character from Sasha-16 (available for free here if you have V4: http://www.sharecg.com/v/88918/gallery/ ... -for-POSER ) and when I went to render her with subdivision level set to 1, her eyes and teeth vanish.  This doesn't happen on V4 default, but I can't see why this would happen.  Unfortunately the maker of Sasha doesn't have access to Octane, and this seems like an issue on the Octane end, so I am curious if there is something that can be fixed on the model side.  If anyone can help, I will pass along the info.
						- Seaking406
Hi, just to test this out for you, I loaded the basic SASHA and one I created with another skin etc..
I am not entirely sure by what you meant by 'rendering with subdivision level set to 1' so I tried it from the OctaneRender Setup window, Materials and selected the model, and at the bottom there is Subd Level settings.. which is the only setting I could find?
Anyway, with both models, nothing really changed.. eyes and teeth still show as normal..
If I used the wrong settings, can you point out to me where it is so that I may try it again?
Aha!  Found the cause, and it's kinda strange.  It seems that the jaws, the eyes and the tongue are all set as "subdivide separately" and forced to 0 subd level.  When you have this with a subd level 1 mesh, it causes the parts that are 0 to not render.  This is DEFINITELY something that needs looking into on the software side.
