Material data is not saved?
Forums: Material data is not saved?
Moderator: BK
Postby Tofusan » Thu Mar 28, 2013 11:17 am
Tofusan Thu Mar 28, 2013 11:17 am
I adjust the material for Octane. Then I saved the scene. I reloaded the saved data. However, after adjusting material was gone. Is not the data should be stored in the duf? Or, do I need special instructions to save the data?
My DAZ Studio version is 4.5.1.6.
Tofusan
Re: Material data is not saved?
Postby guimarconi » Thu Mar 28, 2013 11:34 am
guimarconi Thu Mar 28, 2013 11:34 am
I'm having the same problem here.
Daz: Version 4.5.1.56 Pro 64-bits
Guilherme Marconi - http://brain.marconi.nu
Win8 / Intel i7 CPU 3.06GHZ / 12 GB DDr3
guimarconi
Postby Isotemod » Thu Mar 28, 2013 11:35 am
Isotemod Thu Mar 28, 2013 11:35 am
Hi there could do with a little more information to find out whats going wrong and at what point.
Generally you load content into Daz studio then alter the Octane materials then you can save the Scene. Reloading that scene will have the Octane materials with the alterations you made.
Isotemod
Postby t_3 » Thu Mar 28, 2013 1:35 pm
t_3 Thu Mar 28, 2013 1:35 pm
@Tofusan, @guimarconi:
if you still have problems, can you please...
a) check the path for the temp directory set in the daz studio preferences
b) check if that path does exist, and if there is free space on the drive holding this path
-> if there were troubles with this temp path, please set it to a valid directory.
if you still have problems please...
c) create a Zip file containing:
-- any saved scene (with the plugin of course) - doesn't matter if you altered materials
-- the daz studio log file (in ds go to help > troubleshooting > view log file + save it somewhere)
d) write me a pm with this Zip file attached, and write down the temp file path as set in the daz studio preferences
The obvious is that which is never seen until someone expresses it simply
t_3
Postby Tofusan » Thu Mar 28, 2013 2:12 pm
Tofusan Thu Mar 28, 2013 2:12 pm
@t_3: Thanks for quick reply.
My Temp folder seem to have been set up correctly. To be on the safe side, I tried to set it again. Then, materials are now saved correctly. However, I have a new problem. DAZ Studio crashes when loading the saved data. I'm going to send you the saved data and crash log.
Tofusan
Postby t_3 » Thu Mar 28, 2013 2:17 pm
t_3 Thu Mar 28, 2013 2:17 pm
Tofusan wrote:@t_3: Thanks for quick reply.
ok... will pm you as soon as i know what's going on...
t_3
Postby Tofusan » Thu Mar 28, 2013 3:11 pm
Tofusan Thu Mar 28, 2013 3:11 pm
There seems to be a material that can not be saved again.
Victoria4 materials are saved. materials of Any props are also saved.
However, materials of Genesis figure is not saved.
Tofusan
Postby t_3 » Thu Mar 28, 2013 3:26 pm
t_3 Thu Mar 28, 2013 3:26 pm
Tofusan wrote:There seems to be a material that can not be saved again.
ok, then please send me another pm with a saved .duf which won't load the materials.
apart from that please do a simple test:
- untick the "automatic material updates" in the common tab
- load a _textured_ genesis
- go to the material tab
- - the right hand tree shows now a bunch of colored surface entries for that genesis (means no octane mats linked)
- - the left hand tab is hopefully empty (apart from the live db entry)
- right click the _root_ entry for that genesis figure in the right hand tree, and select "create all 26 as blank"
- you should now see a bunch of (default) octane materials, and both trees should now show everything non-colored
- save it, re-open it, and tell me what you see or post a screenshot of the trees in the mat tab
thanks...
t_3
Postby Tofusan » Thu Mar 28, 2013 3:53 pm
Tofusan Thu Mar 28, 2013 3:53 pm
@t_3:
I conducted the procedure as directed to you.
Materials are lined up in the right-hand side. Nothing in the left.
In my poor English, I may not be able to explain to you well. I attach a screenshot.
Tofusan
Postby t_3 » Thu Mar 28, 2013 4:03 pm
t_3 Thu Mar 28, 2013 4:03 pm
Tofusan wrote:@t_3:
i can perfectly understand you :)
so, this is after reloading? then please, once more, send me exactly that .duf, as Zip attached to a pm; and bear with me, i will need some time to look into this really strange behavior...
t_3
Next
Return to DAZ Studio
Who is online
Users browsing this forum: No registered users and 24 guests
Fri Apr 26, 2024 11:19 pm [ UTC ]
