Possible bug with v1.0.111.2121 Post adj.causes restart
Moderator: BK
JeffGalloway
Making a Post Processing adjustment causes the render to restart.
t_3
JeffGalloway wrote:Possible bug with v1.0.111.2121
does this happen all the time to you? doing a quick test i can not directly confirm this, so i would need a more detailed explanation if possible - thanks!
„The obvious is that which is never seen until someone expresses it simply ‟
JeffGalloway
I just noticed it this evening after installing the new version. I have replicated it several times.
t_3
JeffGalloway wrote:I just noticed it this evening after installing the new version. I have replicated it several times.
hm. actually i can't tell for sure why this might happen. octane only has one single update command to commit whatever whenever changes, the rest is up to the engine. best i can think of is, that there happens something internally, which is captured away since the last update instead letting ds crash, and this subsequently leads to that behavior. so there is a good chance that this will be resolved when these other problems are resolved (changing node types most notably)...
JeffGalloway
Update: adjusting the saturation also triggers a restart.
t_3
JeffGalloway wrote:Update: adjusting the saturation also triggers a restart.
... or any other usually non destructive setting. must be all behave the same. but it should definitely not be the case, if you create something new, without touching i.e. material settings. if this is still the case, i'd indeed need some step by step directions to reproduce this (as it should be possible to reproduce)...
JeffGalloway
I have changed material settings on the file exhibiting this behavior.
Return to “DAZ Studio”
