Problem with Stencil Conversion
Forums: Problem with Stencil Conversion
Postby LFedit » Thu Jun 01, 2017 4:58 pm
LFedit Thu Jun 01, 2017 4:58 pm
When I bring in a JPEG, and I have to use it as an Opacity map, or Stencil in modo terms, it wont convert on the fly. Is there a reason for this? Am I using the wrong image format or something?
So what I have to do is convert it to an octane override, then it puts the correct map in the opacity slot, but its an alpha image, then it doesn't work. If I make a RGB image, then just reapply the exact same pins, it works.
Am I doing something wrong? Would be great to be done with Octane overrides!
Almost forgot, Modo 902 sp3 OctaneRender 3.06 TEST 4 (3060003)
Win 7 64bit/ Nvidia Maximus k5000 and k20
LFedit
Re: Problem with Stencil Conversion
Postby face_off » Thu Jun 01, 2017 11:38 pm
face_off Thu Jun 01, 2017 11:38 pm
Can you provide a screenshot of the shader tree and the stencil image settings pls?
Postby LFedit » Fri Jun 02, 2017 8:48 pm
LFedit Fri Jun 02, 2017 8:48 pm
sure. Here you go. I even showed how I converted it to an octane override and it still didn't work.
Also attached a shot of how the rgb image does work then.
LFedit
Postby face_off » Fri Jun 02, 2017 10:24 pm
face_off Fri Jun 02, 2017 10:24 pm
Can you send me the scene and image pls?
Postby LFedit » Mon Jun 05, 2017 2:47 pm
LFedit Mon Jun 05, 2017 2:47 pm
You bet. Here you go.
OpacityPorblem.zip
(280.87 KiB) Downloaded 312 times
LFedit
Postby face_off » Tue Jun 06, 2017 6:50 am
face_off Tue Jun 06, 2017 6:50 am
Your stencil is a JPG - which the Octane plugin assumes does not have an Alpha channel. But you have Alpha Channel = Use for that image. So change Alpha Channel to Ignore, and it works.
Postby LFedit » Tue Jun 06, 2017 2:16 pm
LFedit Tue Jun 06, 2017 2:16 pm
ahhhhh...
Thank you! Saves me time!
LFedit
Postby Kilian » Tue Aug 01, 2023 10:28 am
Kilian Tue Aug 01, 2023 10:28 am
Thanks. I had the same problem some years later.
Kilian
Return to Foundry Modo
Tue Jun 04, 2024 6:42 am [ UTC ]
