Lights in octane
Forums: Lights in octane
Lights in octane
Postby vandijkjacques » Sat Jun 11, 2011 10:06 am
vandijkjacques Sat Jun 11, 2011 10:06 am
Hello,
When i setup a scene in Blender with multiple lights, all these lights have disappeared in octane.
And i am just left with the environment lamp in octane.
Does anybody have any ideas?
vandijkjacques
Re: Lights in octane
Postby face » Sat Jun 11, 2011 12:23 pm
face Sat Jun 11, 2011 12:23 pm
Maybe because Octane can´t import lights?
face
http://vimeo.com/user2509578
face
Postby Jaberwocky » Sat Jun 11, 2011 1:34 pm
Jaberwocky Sat Jun 11, 2011 1:34 pm
vandijkjacques wrote:Hello,
You need to make some mesh lights in Blender.
They will export along with your scene.
Then assign them as blackbody emitters in Octane.
Make sure the scale is correct though.Its critical that the size is not outlandish.IE 600mtr high ceilings for example of they wont work.
also once the light mesh's are in Octane you could also assign them as IES lights using a profile if you need some accuracy.
Hope that helps.
The Jaba
Jaberwocky
Postby vandijkjacques » Mon Jun 13, 2011 5:58 pm
vandijkjacques Mon Jun 13, 2011 5:58 pm
Hi Jaba,
That’s a good suggestion. :)
I did notice the mentioning of the ies files in the manual.
The manual does however not explain what to do with the ies files.
To bad, it looks promising.
I like Octane, but it needs a good manual.
vandijkjacques
Postby Jaberwocky » Mon Jun 13, 2011 8:38 pm
Jaberwocky Mon Jun 13, 2011 8:38 pm
vandijkjacques wrote:Hi Jaba,
take a look at the attached link
viewtopic.php?f=33&t=6834&start=100
I put an entry into that page with a screen grab of where to put the IES file
Regards
the Jabba
Jaberwocky
Postby vandijkjacques » Thu Jun 16, 2011 6:24 pm
vandijkjacques Thu Jun 16, 2011 6:24 pm
Thanks! ;-)
Indeed , that simple huh ;-)
vandijkjacques
Postby orion_uk » Wed Oct 26, 2011 3:32 am
orion_uk Wed Oct 26, 2011 3:32 am
Is there a way of hiding the mesh light/emmiter from the camera (while still casting rays)..?
Just got Octane full today (for use with blender)..thank you ;)
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
Postby face » Wed Oct 26, 2011 6:48 am
face Wed Oct 26, 2011 6:48 am
To set the opacity to 0 should make the emitter invisible.
face
face
Postby orion_uk » Wed Oct 26, 2011 7:12 am
orion_uk Wed Oct 26, 2011 7:12 am
Getting use to a new GUI/app can make the most simple things seem confusing :P
Apprieciate you taking the time to help, thank you :)
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
Return to Blender
Who is online
Users browsing this forum: No registered users and 3 guests
Fri Jul 03, 2020 8:59 pm [ UTC ]
