Preview render and final render does not match
OutOfTime007
Hello,
My preview in octane camera and the final render is different. How do I fix? I might have changed some things myself, but can't figure out how to set it back.
J.C
Check the Blender's color management settings. Display device should be set to "NONE". The rest settings should be default. Don't forget to enable "Octane imager" in camera tab settings.
System – Windows 11
OutOfTime007
The display device was set to sRGB. Settings it to none Solved it. Thank you.
Dmi3ryd
Unfortunately it did not help.
Dear Azen, cjuld you please fix this in future releases?
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
J.C
It's not a bug. It's beed discussed before. You need to set the proper values into Color management tab and enable Octane imager on active camera.
Same topic few lines below.
viewtopic.php?f=32&t=63100
System – Windows 11
Dmi3ryd
This did not help. Still incorrect display.
J.C
Can you provide your .blend file to check?
System – Windows 11
Return to “Blender”
