Note that this demo version does not require the standalone edition, however the licensed version requires both an OctaneRender Standalone edition license and an OctaneRender for SketchUp® Plugin license.
KyriakosCY wrote:Thanks for the reply! As I mentioned above, I installed the demo version of the Sketchup plugin which does not require the standalone to be installed at all, let alone a version below. This is what it says on the demo download page:Note that this demo version does not require the standalone edition, however the licensed version requires both an OctaneRender Standalone edition license and an OctaneRender for SketchUp® Plugin license.
However, your reply has given me an idea... I am running an older version of the Nvidia drivers for better compatibility with the older 5 series cards... This may be to the problem... what do you think..?
KyriakosCY wrote:Hi,
It must have been the drivers, as once I updated them all was well and back to normal... When I load a model or sketch up scene and open the viewport it takes some time (seconds) to convert the mesh etc and then once that process has finished I have to move the camera a few degrees here and there to make the scene visible in the viewport. If I do not do this it stays grey... Is this a bug, or something to do with my scene..?
Also, will the standalone lighting models be transferred into the plugin, as the sketch up lighting is quite limited compared to the standalone...
Thanks!
Users browsing this forum: No registered users and 2 guests
