save materials?
Forums: save materials?
save materials?
Postby Jorgensen » Sat Feb 18, 2017 8:43 pm
Jorgensen Sat Feb 18, 2017 8:43 pm
hi
i use plugin version 3.04.4.5, and i wonder how do i save my octane materials so i can use them in other projects?
thanks
jorgensen
Jorgensen
Re: save materials?
Postby fivebythree » Wed Feb 22, 2017 9:36 am
fivebythree Wed Feb 22, 2017 9:36 am
Local DB material creation from standalone. But not creation in Sketchup.
STANDALONE WINDOWS10PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
fivebythree
Re: save materials?
Postby Jorgensen » Wed Feb 22, 2017 10:51 am
Jorgensen Wed Feb 22, 2017 10:51 am
can i create them in the standalone and use them in sketchup?
thanks
jorgensen
Jorgensen
Re: save materials?
Postby azen » Wed Feb 22, 2017 10:17 pm
azen Wed Feb 22, 2017 10:17 pm
Jorgensen wrote:can i create them in the standalone and use them in sketchup?
thanks
jorgensen
With the completion of the new interface, we will have more direct control over what can be exposed via our own interface. We will be able to implement LocalDB directly into the plugin. Apologies for the inconvenience.
Cheers,
Azen
azen
Re: save materials?
Postby smicha » Wed Feb 22, 2017 10:20 pm
smicha Wed Feb 22, 2017 10:20 pm
When?
smicha
Re: save materials?
Postby fivebythree » Fri Mar 03, 2017 5:41 am
fivebythree Fri Mar 03, 2017 5:41 am
This is how to do it.
Works for more advanced materials that can cause troubles in the plugin.
fivebythree
Re: save materials?
Postby Jorgensen » Wed Mar 15, 2017 8:47 am
Jorgensen Wed Mar 15, 2017 8:47 am
hi fivebythree
thanks a lot - i'm a very standalone noob.... is there a template for creating materials?
as i see in your screenshot, you don't have ny geometry?
thanks
jorgensen
Jorgensen
Re: save materials?
Postby bepeg4d » Wed Mar 15, 2017 3:23 pm
bepeg4d Wed Mar 15, 2017 3:23 pm
Hi jorgensen,
you don't need geometry nodes for creating materials in Standalone. Right click anywhere in the node graph and create a material node. Right click on it and choose Render.
The material will be rendered in a preview scene called Material ball:
If you click the orange marked icon, the material ball will be instantly activated without right clicking on the node.
ciao beppe
Re: save materials?
Postby Jorgensen » Wed Mar 15, 2017 4:25 pm
Jorgensen Wed Mar 15, 2017 4:25 pm
ahh that was smart / simple - learning new things every day :-)
thanks beppe
jorgensen
Jorgensen
Re: save materials?
Postby fivebythree » Fri Mar 17, 2017 7:36 pm
fivebythree Fri Mar 17, 2017 7:36 pm
No problem. I'm taking the time to learn it because its AMAZING! SketchUp plugin has a long way to go. Usually model in SU then export orbx to standalone these days. Material handling and rendering settings are so much easier to use.
fivebythree
Return to SketchUp
Tue Jun 04, 2024 9:06 pm [ UTC ]
