Any Idea where my Render Pass tab has gone?
creativebloke
It was there yesterday I swear, but now I upgraded to 2.25 R2, and then downgraded back to 2,24,2 but in both cases my Render Passes tab has disappeared?
twitter = creativebloke
zoppo
(C4D) Render Settings -> Octane Render -> Render Passes tab?
C4D 2025 | Win10
creativebloke
Hi, the render settings is there, just not in the octane settings dialogue which lets me preview the passes - its very odd
creativebloke wrote:Hi, the render settings is there, just not in the octane settings dialogue which lets me preview the passes - its very odd
That's wrong! You can see as in Live Viewer as previous system. You need to set "enabled" and select any passes. Didn't you checked like that?
zoppo
Now I think I understand - as Aoktar said, choose the Chn: in the LV window. In the Octane Settings the Kernel tab changes to "Infochannels", there you find your settings.
C4D 2025 | Win10
zoppo wrote:Now I think I understand - as Aoktar said, choose the Chn: in the LV window. In the Octane Settings the Kernel tab changes to "Infochannels", there you find your settings.
Not sorry. You should select from Octane Render Settings->Passes->Enabled. And select any pass in this section as doing output settings. LV will show all active passes as buttons in LV's bottom area.
zoppo
I think he is talking about this window:
C4D 2025 | Win10
creativebloke
zoppo wrote:I think he is talking about this window:
Yes thats correct, its that window the passes tab was there, now its not - very odd
zoppo
creativebloke wrote:Yes thats correct, its that window the passes tab was there, now its not - very odd
Just enable Z-Depth in the Render Settings, then switch to the Kernel tab in the Octane Settings and choose Infochannels as kernel.
C4D 2025 | Win10
creativebloke wrote: Yes thats correct, its that window the passes tab was there, now its not - very odd
Why i couldn't explain it well? I have simplified the usage of passes just from single section in render settings. To avoid conflicts due having same controls in two different sections.
