Octane for Softimage 3.00 RC2 Demo/Full [Obsolete]
Forums: Octane for Softimage 3.00 RC2 Demo/Full [Obsolete]
Autodesk Softimage XSI (Developed by Face)
Postby face » Sat Sep 16, 2017 6:46 am
face Sat Sep 16, 2017 6:46 am
Ok, here is the first update for V3.
Hope you enjoy,
face
FIXED:
  • ICE Particle Orientation from Euler Rotation is now correct.
  • ICE Point Segment Size wasn´t used, which is fixed.
  • Swapped the "Tonemap Type" under the Misc settings.
  • Motionblur is now working correct with subframes.
ADDED:
  • Added support for deformed motionblur.
  • Added parameter for deformed motionblur subframes.
  • Added parameter to enable deformed motionblur for each mesh in the mesh properies.
  • Added scene for motion blur.
  • Added scene for deformed motion blur.
  • Added scene for texture baking.
  • Added Octane materials to Get -> Material
CHANGED:
  • Changed default Point Segment Size from 0.0025 to 0.025.
  • Changed the kernel in the render layer scene to info channel / render layer id, to show the layer colors .
DOWNLOADS
INSTALLATION INSTRUCTIONS
    This plugin can be installed with the usual way. Unzip the downloaded OctaneV3.zip, drag and drop the xsiaddon in the Softimage window.
    You can also use the File -> Addon -> Install menu.
KNOWN ISSUES
    Motion blur and Render Layer for Pointclouds will be added in the future.
    Also the possibility to use Pointclouds as instance shapes.
http://vimeo.com/user2509578
face
Re: Octane for Softimage 3.00 RC2 Demo/Full [Current]
Postby wireframex » Sat Sep 16, 2017 9:42 pm
wireframex Sat Sep 16, 2017 9:42 pm
Thanks Face !
Main Computer:
Ryzen 2990WX / 64Go Ram / 1 GTX 1070 8Gb (Display) + 2 GTX 1080 8GB
OS: Windows 10 x64 - NVidia Driver 431.60 - Octane Plugin Build 2019.1.0.1
Licensed: Softimage 2012 SP1 / Lightwave 2019.1.4 / modo 13.1
wireframex
Postby rray » Mon Sep 18, 2017 9:21 pm
rray Mon Sep 18, 2017 9:21 pm
Thanks for the update!
Core i7 980 x GTX 980
rray
Postby face » Wed Sep 20, 2017 2:32 pm
face Wed Sep 20, 2017 2:32 pm
Thank you.
Will now integrate particle motion blur which will work the same as in MentalRay.
You need also a point velocity, without it, no motion blur is created.
This means also, if your shape is a box, no rotation blur will be applied, only position blur.
face
Return to Autodesk Softimage XSI
Who is online
Users browsing this forum: No registered users and 2 guests
Tue Jan 21, 2020 9:08 am [ UTC ]
