OctaneRender® for Maya® 2.24.2 - 7.13 Win [OBSOLETE]
Locked
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Memory usage improvements for animation translation.
  • Fixed projection and transform loading from LiveDB for noise texture.
  • Fixed visibility issues with instances groups.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.13 (12.5MB autoinstaller file)
OctaneRender for Maya 2.24.2 - 7.13 Demo (11.6MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
prodviz
Cheers Jim.
No luck with the procedural displacement?
In the substance shaders, there's a bake command '$sbs_AutomaticBakeCheck = 1;' for automatically baking textures on the fly. Hope this helps.
Cheers.
renmaxhb
Maya crashed alwaiys when Oct render instancer motion blur, or I dont know the skill?
Jolbertoquini
Thanks for the Fix Jim 8-)
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Refracty
Thanks for the update.
I am testing the motion blur feature because it gave me trouble sometimes but I don't understand why is it crashing / stopping sometimes.
I have setup a simple scene with a sphere moving from A to B (with a key on position A and B). A is at frame 1. When I set a key for posiotion B at frame 30 and try to render from frame 1 to 30 it is stopping because Octane4Maya needs more frame to solve the motion blur (10 MB time samples). So I set it to 19 and it works. Ok sounds logically so far. But sometimes it behaves strange. I use the same setup with 40 frames and set the batch duration from frame 1- 25 and it will still crash/stop.
I hope that the motion blur issues will be fixed. I know that there might be a logic behind, but this should be fixed automatically or at least give a hint in the feedback promt to know how the user can fix this.
jonathanhadley
Hi Jim,
Any news on when or if we will get coloured lights back instead of temperature controlled?
zboog
Any news on when we'll get Octane render layers to export in batch mode? I.e., some way to save out all the render layers without having to manually render them one by one?
avajjon
I was just testing the open subdiv rendering within maya. The Octane Level attribute is working fine when we set to Geometry type to Reshapable Proxy mode. Sharpness is also working when I try to increase the amount. The problem is once sharpness is set to a value, it is ignored when I stop the ipr render and render second time around. if I play with the sharpness value again, it does apply the sharpness again. The sharpness value not sticking.
Jolbertoquini
jonathanhadley wrote:Hi Jim,
I think we should have bouth temperature and a option to plug any texture colour on the lights. Sometimes is really good to have as a any render engine like Iray, Redshift,cycles and etc.. Gpu render. But again that's my point the view.
Next version HERE.
Locked
Return to “Autodesk Maya”
