OctaneRender® for Maya® 2.23.2 - 7.9 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Implemented OctaneRender support for the new Maya 2016 feature: Material Viewer. Remember that whenever your Octane live-rendering session is active - material viewer will not be refreshing.
  • Fixed the bug: Octane panoramic camera didn't work correctly with the scene scale set other than 1.0.
  • Post processing pass is back.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.23.2 - 7.9 (12.4MB autoinstaller file)
OctaneRender for Maya 2.23.2 - 7.9 Demo (10.9MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
SimonPercy
Do these installers have a silent mode for distribution?
Darkside Studios London
Feature Film & TV Visual Effects and Animation
14 Grays Inn Road, London, United Kingdom
http://www.darksidestudios.uk
Refracty
Hi Jimstar,
When I try to batch render a scene, the Maya Batch render is crashing, so I can not get an animation out with Octane4Maya. The IPR works fine.
But when I click on batch render in the Render Menu, a window pops up that says Maya Batch just stopped working.
I need to find a solution quickly.
System: Win 7 - 64bit - Maya 2015 - Octane4Maya 2.23.2 - 7.9 Win
Scene: Instanced nParticles with a turbulance field and Per Particle Attributes for ID, Scale and Rotation
Render Log Output in Verbose mode:
9/4/2015
Starting "C:\Program Files\Autodesk\Maya2015\bin\mayabatch.exe"
QWidget: Cannot cr// Maya exited with status -1073741819
Refracty
The batch rendering works fine on my test scenes...
Could you give me the scene where it is reproducable for you?
Refracty
Hi JimStar,
I have tested the Batch rendering with a different renderer. It is still crashing, so this issue is not a Octane4Maya problem.
blackshore
Is Out-Of-Core feature verified to work on this version?
zurakan
HI jim thank of update
i found bug for me
1. when i delete Unused Nodes in Hypershade , all octaneLight is gone in Outliner
2. i assign texture to Octane shade , but in viewport is not display
thank you so much
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
itsallgoode9
zurakan wrote:HI jim thank of update
i found bug for me
thank you so much
It deletes the octane sun sky too
SimonPercy wrote:Do these installers have a silent mode for distribution?
No, they don't support the silent mode in current versions.
Refracty
I am using multiple Render Plugins in Maya for visualisation purposes with models in Z-UP.
Is there a way to change the scene up (for Octane)?
When I set the Scene to Z-Up in the Maya prefs, Octane will not use this information and it will still show the rendering with a Y-Up camera.
So the renderings don't match.
I could rotate the model to Y-Up and only work in Y-Up but this would not be the best way in this case because I import and export things frequently.
Locked
Return to “Autodesk Maya”
