Install Octane Demo for Cinema4D R21.. but tab missing??
xijpxi
So i've downloaded and installed the Octane demo to my "Plugins" folder for Cinema4D R21, but upon re-launching the "Octane" tab doesn't seem to appear nor is it in the "Extentions" tab. I've also triple checked that i do have my plugins folder location set in settings.. it's just not appearing no matter what i do. (pics attached for reference..)
Also, was considering just renting monthly. if I decide to go ahead and rent.. will that work? Is the setup/installation different than the demo?
Firstly you need to upgrade C4D to R21.115 or greater, or plugin cannot be correctly loaded, please go to c4d menu Help/Check for updates.
At the moment, only the following AMD GPU are supported in OctaneX under Mac Os Catalina 10.15.6:
- Radeon Pro Vega II Duo - 412 OB*
- Radeon Pro Vega II - 206 OB
- Radeon VII - 200 OB
- 5700 XT - 170 OB
- Vega FE - ~161 OB
- Vega 64 -~148 OB
- Vega 56 - ~117 OB
- Vega 48 - 108 OB
- 5600M - 108 OB
- 5500M - 77 OB
- Vega 20 - ~50 OB
- WX9100 - ~ nd
We are expecting to have the full Metal support of AMD GPUs in the upcoming Mac Os 11 Big Sur.
Looking forward for your feedback,
juliangwan
I know this is probably a "you shouldn't have upgraded to the Big Sur public beta" issue, but I did upgrade and now the Metal preview doesn't work.
I'm getting this error:
Compute error 2097152:113:
compute device 0: Linking 6d197dfc90d19e72 shader failed
device 0: failed to initialize render thread 0x7f85a6f46940
could not pick, because we have no render threads
Using a AMD Radeon Pro W5700X 16 GB on a Mac Pro, Octane Metal, and Latest C4D.
Are there any tips you might know to regain Octane functionality? I know I've doubled down on Betas, but this is on a machine I only use for high intensive graphics, and Final Cut Pro, so the beta is smooth sailing otherwise.
my suggestion is to perform a Clean install of Catalina on an external hdd/ssd, Big Sur beta does not have the proper Apple Metal driver for running OctaneX.
My iMac has four os in it, High Sierra, Catalina, Big Sur and Win 10 ;)
ciao Beppe
juliangwan
bepeg4d wrote:Hi,
ciao Beppe
Grazie Beppe.
Is it possible to join the beta for the Big Sur metal drivers? It's frustrated with Apple delaying Big Sur... And I can't use Octane right now :(
No sorry, the beta testing group is a closed group, and has been chosen by Apple several months ago.
Better to install also Catalina, Big Sur beta is not ready for production.
ciao Beppe
juliangwan
bepeg4d wrote:No sorry, the beta testing group is a closed group, and has been chosen by Apple several months ago.
ciao Beppe
Thank you for your reply. I will stay patient until I know more.
