OctaneRender™ Standalone 4.04
haze
Hi all,
A couple of last minute critical changes came up, which we include in this release.
We recommend that you update to driver version 419.17 or later.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
If you have any issues during this process, please get in touch with our support team.
New GPU requirements
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changes since version 4.03:
  • Fixed a dongle activation issue.
  • Fixed exporting scenes from plugins that contain animated transforms with zero matrices.
  • Fixed a crash when stopping render, and then previewing a material in the node stack. This also caused crashes in plugins that use the same mechanism to render thumbnails and material preview tiles.
  • Fixed a crash during activation on some machines with RAID setups.
  • Fixed denoiser black pixels.
Downloads for users with a regular license
OctaneRender for Windows (installer)
OctaneRender for Windows (zip)
OctaneRender for Linux
OctaneRender for Mac OS
Downloads for users with a Studio subscription license
OctaneRender Studio for Windows (installer)
OctaneRender Studio for Windows (zip)
OctaneRender Studio for Mac OS
OctaneRender Studio for Linux
Downloads for users with Creator (Enterprise) subscription license
OctaneRender Creator for Windows (installer)
OctaneRender Creator for Windows (zip)
OctaneRender Creator for Mac OS
OctaneRender Creator for Linux
Demo version downloads
OctaneRender Demo version for Windows (installer)
OctaneRender Demo version for Windows (ZIP archive)
OctaneRender Demo version for Mac OS X (DMG image)
OctaneRender Demo version for Linux (ZIP archive)
funk
Thanks OTOY
grimm
I noticed that the volume denoiser isn't working quite right. The very edges of the volume are not being denoised even though I have the volume denoiser turned on. I can see the noise in 4.03 as well.
Here is the Disney cloud rendered at 100 spp:
And here is the denoiser output for it:
Jason
Jolbertoquini
Hi Guys,
We are having some issues with our internal tools with the 4.0.4 : viewtopic.php?f=73&t=71439&e=0
basically this:
I'm trying to query pin names/labels for the NT_GEO_GROUP and have found that this used to work in Octane 3.06.4 but now no longer works in Octane 4.04. Has this API changed? I've checked in the documentation and there are no differences that I can see. For example with the following script:
local geogroup = getNodeTypeByName("MyGeoGroup", octane.NT_GEO_GROUP)
if (geogroup ~= nil) then
  print(geogroup:getPinCount())
  for jj=1,geogroup:getPinCount() do
    local lp = geogroup:getPinInfoIx(jj)
    print("description " .. lp.description .. " type " .. lp.type .. " label " .. lp.label .. " name " .. lp.name)
  end
end
Octane 3.06.3 Output:
1
description Geometry Input type 12 label Input 1 name Input 1
Octane 4.04 Output:
1
description Geometry Input type 12 label name unknown
I can see in the Node inspector UI that for both versions the pin details have the name as "Input 1", so am confused why I cannot query this string in the newer version of Octane?
So after a extra test is coming after the version 4.0.3 which seams this update "Fixed octane.node.getPinInfoIx().name which was returning the label instead of the pin name." is giving errors to us based on the script on the top the Octane version 4.0.2.1 is working fine.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Scrudje
Win 10 64 | Geforce Titan black x2 | i7-5960x | 16GB
Jolbertoquini
Scrudje wrote:fix this bug
viewtopic.php?f=81&t=71297
I would say you need check with the Plug developer aswell because Octane doesn't export JPG only "PNG and EXR" so the png is accurate is clear a problem of preview from the 3DSMAx plug.
EDIT: Oh I see not clear direction on the problem here on the Post, The actually issue is on the Specular shader "Affect alpha" is not doing accurate alpha.
I guess could be two things the options on the imager the Premultiplied alpha or for some reason the plug is doing something wrong while showing the alpha on the viewer interesting I will check on the standalone from my side to.
Best,
JO
Jolbertoquini
Hi There,
This will help Standalone side and actually I have the same problem with in Photoshop basically Nuke and other get well AE aswell cause you have a option to ignore alpha.
The problem is Photoshop which are doing a premultiply the image when imported Nuke are showing accurate results without loosing reflections. here raw file and result from Nuke and Photoshop, I think the preview from Max is multiplying the result on the wrong way as Photoshop.
here a way to make work in Photoshop http://www.fnordware.com/superpng/ or get a exr and import the transparency as alpha.
So basically is working we are not loosing details when import and other softs for compositing such nuke for example:
on the scene settings just activate alpha "don't activate keep environment" and activate "affect alpha" on the specular shader then just open and activate "premultiplied" on the read node options at nuke.
For Photoshop I supposed you need do a import with premultiplied the result. I will post soon a way maybe to get into photoshop as in Nuke
Hope this help you. But maybe something strange with power I feel on the highlight range is a bit lower and looses range on the highlight
Best,
JO
Jolbertoquini
Hi There,
I did more further tests on multiple projects, and yes as "Scrudje" mentioned on the 3dsmax group, is quite funny the way the alpha is giving results, they are not really right, the "affect alpha" doesn't work really well after a while testing on different glass shaders.
The result is always a bit different, personally I Like to use visible environment to change my backplate because a lot refractions are lost, but right now I have a impression is specially highlights...
I tried as EXR no tonne mapping and is pretty much the same.
Best,
JO
Scrudje
Jolbertoquini wrote:Hi There,
Best,
JO
It is good when someone understands you :D , but the problem remains a problem :roll:
1. For compose and not only I use only PS.
2. I tried to install SuperPNG plug-in, but it does not work in my version of PS CC 2018. Png file opens without SuperPNG pop-up menu. I read manual and made as there is written, but nothing turned out((
Jolbertoquini
Jolbertoquini wrote:Hi Guys,
basically this:
  end
end
1
Octane 4.04 Output:
1
Best,
JO
Hi Haze,
Any news please we kind need a quick fixe to work with our internal tools
Best,
JO
