Fur thickness attribute ?
Houdini Integrated Plugin
WoutTgh
is the fur thickness attribute accessible on a point per point basis ?
juanjgon
The Octane plugin gets the fur thickness from the "width" float point attribute, if available in the curve primitives.
WoutTgh
Oh, interesting, that seems to work, but what about the tip thickness ? thanks !
galleon27
WoutTgh wrote:Oh, interesting, that seems to work, but what about the tip thickness ? thanks !
Just do a gradient on curves and call it width.
If you use resample node and turn on curveu attribute, you should be able to do it easily. Turn off resampling if you don't need it.
After that create a wrangle node and write @width = @curveu;
@curveu attribute goes from 0 to 1 so you can fit it to whatever value you want. So the code should be:
@width = fit01(@curveu, min, max);
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
WoutTgh
ooh of course, cool. And then just keep the obj paramteres setting at the default, or both 1 or whatever.
Thanks ! :)
galleon27
WoutTgh wrote:ooh of course, cool. And then just keep the obj paramteres setting at the default, or both 1 or whatever.
Thanks ! :)
Yea keep it at default, it doesn't really matter. If you have width attribute, it's gonna override whatever you have in obj level.
WoutTgh
Yes, thank you, very helpful :)
Return to “Houdini”
