OSL compile error with boolean widget
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ChrisH
Hi, I found a problem with OSL compilation.
I've tested this in both "Octane Blender" (27.16 / 3.5.1) and with the add-on (27.16.3 / 3.6.1)
(I've also tested the OSL script in the Octane Node Graph, and Cycles, where it works fine)
The problem is that you can't have an int as an boolean widget, you can't have it enabled by default.
Relevant line ("full" example bellow and attached):
      int use_a = 1 [[string label = "Use A", string widget = "boolean"]], // This DOESN'T work!
//    int use_a = 0 [[string label = "Use A", string widget = "boolean"]], // This works
And it gives this error:
Traceback (most recent call last):
  File "C:\Users\chris\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\octane\nodes\base_osl.py", line 439, in invoke
    node.compile_osl_node(self.report)
  File "C:\Users\chris\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\octane\nodes\base_osl.py", line 392, in compile_osl_node
    reply_data = str(ET.fromstring(response).get("content"))
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\python\lib\xml\etree\ElementTree.py", line 1342, in XML
    parser.feed(text)
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 3, column 127
Error: Python: Traceback (most recent call last):
    parser.feed(text)
Example:
shader Switch(
    color col_a = 0 [[string label = "A"]],
    color col_b = 1 [[string label = "B"]],
    output color out = 0 [[string label = "Output"]]
    if (use_a)
        out = col_a;
    else
        out = col_b;
Test.osl
(423 Bytes) Downloaded 76 times
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
Return to “Bug Reports”
