I am writing some scripts changing the parameters of texture image
and I want to set the Color Space of it.
For example:
tnode.parm('colorSpace').set('Non-color Data')
tnode.parm('colorSpace').set('ACEScg')
but I get error on log when I load it into Octane.
Changing Image Texture's parm via python
lionlee19 wrote:I am writing some scripts changing the parameters of texture image
For example:
tnode.parm('colorSpace').set('NAMED_COLOR_SPACE_OTHER')
tnode.parm('colorSpace').set('NAMED_COLOR_SPACE_ACESCG')Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Thank you Very much !galleon27 wrote:lionlee19 wrote:I am writing some scripts changing the parameters of texture image
For example:
but I get error on log when I load it into Octane.Code: Select all
tnode.parm('colorSpace').set('NAMED_COLOR_SPACE_OTHER') tnode.parm('colorSpace').set('NAMED_COLOR_SPACE_ACESCG')
It works!
Where can I find these correct parameter names for each colorspace?
Don't know if you can list them all. I just set it to whatever color space i need and do node.parm('colorSpace').eval() in the python shell and you'll get the name. That goes for whatever parameter you need.
Thank you so much!galleon27 wrote:Don't know if you can list them all. I just set it to whatever color space i need and do node.parm('colorSpace').eval() in the python shell and you'll get the name. That goes for whatever parameter you need.
