OctaneRender 2022 for Poser [OBSOLETE]
Erick
Thanks for the update.
... and as always, much appreciated! :D
Khuri
Thank you for the update!
- The "Sun Light" now sets the Sun Direction of the Planetary Environment
That might not be working still. If I choose Planetary Environment and rotate the light source that is renamed to "Daylight" automatically, it does not affect the sun position while using Planetory Environment.
Or am I missing something?
Unfortunately I'm also still getting the subdivision not working problem as described here.
The plugin does show version "2022.1.1.120" though.
Erick
Khuri wrote:Thank you for the update!
I was finally having some time today, to play around with the 2022.1.1120 version of the plugin and yes, I can confirm, the SD issue is still present. Not even the workaround from the other thread seems to work anymore now.
Planetary Envi does work tho. It requires a scene refresh (it needed a scene refresh as mentioned somewhere, after that, switching back and forth between Daylight and Planetary Envi seems to work properly, while changing the "Daylight" in Poser, the effect was visible in the Render) .... I'm using Poser 12 still.
Edit .. hm, having switched a bit back and forth between PE, DE and TE (Texture Envi) PE didn't work anymore. After having restarted Poser, it worked again as it should.
Yes, I see the issue. My apologies. The update to python3 has created some oddities with wx.python - so when you hit enter on the subd field it is not 'sticking'. I will find a fix.
I have posted a TEST build of the plugin for Octane 2023.1 at viewtopic.php?f=45&t=82277&p=428156#p428156. There will be no further Octane 2022.1 builds of the plugin.
Return to “Poser”
