HELP! Duplicated frame problem
Discussion Forum for the Render Network
For support questions please visit help.otoy.com or contact [email protected]
STNLY
Hi Beppe,
when using the command line method the ORBX for RNDR it won't export (I used spaces between the lines). I get this message at the end:
https://imgur.com/vN8KTBd
Can you help me with this issue?
Exporting from C4D R21 with Octane X PR11.
it could be an issue with materials conversion.
About materials and .orbx export, please follow these steps:
- Open the scene in c4d, select all materials, then go to Live View menu Materials/Convert Materials, then Remove unused Materials commands, to remove any C4D material in the scene.
- Then go to Live View menu Materials/OctaneTexture Manager, and check that there are no missing texture files in the scene.
- Please also check that all the textures are listed as ImageTexture, not Bitmap.
Please, always use an ImageTexture node before loading any kind of image into c4doctane:
https://docs.otoy.com/cinema4d/ImageTexture.html
Octane is a Spectral render engine, so every texture must to be converted to the proper color space before been used.
This is even more important for Lighting, and in particular for Emissive materials or Environment node.
- Please also check that there are not c4d Shaders in your scene, unless they are C4D Noise or Gradient nodes.
Most of the c4d native shaders are baked on the fly, but this automatic option slows down the process (especially in complex scenes) because the textures are rendered and updated at every interaction, plus, not all the shader are completely supported. In particular, the Layer shader is not support and you can have incorrect results, and instability. But most important, c4d Shaders cannot be supported in Standalone/RNDR.
From RC3 there is a new option for auto converting c4d shaders into OSL Octane nodes, that is far more stable and productive.
Currently it works for C4D the Noise and Gradient nodes:
So only keep the OSL option active, and disable the auto baking option.
ciao Beppe
ProTharan
Hi Beppe,
Following the command line export, i'm getting this error:
Last login: Wed Feb 9 10:16:28 on ttys000
ptharan@PMIUKGLSMC0153 ~ % /Applications/Maxon\ Cinema\ 4D\ R25/Cinema\ 4D.app/Contents/MacOS/Cinema\ 4D /Users/ptharan/Documents/Cinema\ 4D\ Scenes/JNSC/JNSC1.c4d -nogui -exportORBX /Users/ptharan/Documents/Cinema\ 4D\ Scenes/JNSC/JNSC1.c4d
Application start : 02/09/22 at 10:26:59
Executable : 64 Bit
Version / Build : 25.117 / 25_0.CL363640.28201
Debugger : not available
Memory model : release
Startup path : file:///Applications/Maxon Cinema 4D R25
Application path : file:///Applications/Maxon Cinema 4D R25/Cinema 4D.app
Application executable : file:///Applications/Maxon Cinema 4D R25/Cinema 4D.app/Contents/MacOS/Cinema 4D
Resource path : file:///Applications/Maxon Cinema 4D R25/resource
Module path(s) : file:///Applications/Maxon Cinema 4D R25/corelibs; file:///Applications/Maxon Cinema 4D R25/plugins; file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins; file:///Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13
Temporary path : file:///var/folders/kd/pd__8bbn5ls_zqc3p8t12dhr0000gp/T
Prefs path : file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE
Global Prefs path : file:///Users/ptharan/Library/Preferences/Maxon
OS version : macOS: Version 12.0.1 (Build 21A559)
OS languages : {en-GB}
App languages : {en-US}
Startup language : en-US
Processor : 10(10)x Apple M1 Max
Computer name : PMIUKGLSMC0153
Unique OS identifier : FYVNJQXVH6 [serialkey]
Thread Count : 10
CPU Speed (MHz) : 0.000
Application Type : Modular
Command line arguments : "/Users/ptharan/Documents/Cinema 4D Scenes/JNSC/JNSC1.c4d" "-nogui" "-exportORBX" "/Users/ptharan/Documents/Cinema 4D Scenes/JNSC/JNSC1.c4d"
Loading from directory file:///Applications/Maxon Cinema 4D R25/corelibs:
crypt.module.xlib with module net.maxon.crypt
gui.module.xlib with module net.maxon.gui
image.module.xlib with module net.maxon.image
image_avfoundation.module.xlib with module net.maxon.image_avfoundation
asset.module.xlib with module net.maxon.asset
c4d_viewport_nodegraph.module.xlib with module net.maxon.c4d_viewport_nodegraph
c4dplugin.xlib with modules net.maxon.rlmlicensing net.maxon.c4d.c4dplugin
command.module.xlib with module net.maxon.command
corenodes.module.xlib with module net.maxon.corenodes
crashhandler.module.xlib with module net.maxon.crashhandler
denoiser.module.xlib with module net.maxon.denoiser
drawport.module.xlib with module net.maxon.drawport
drawport_functioncache.module.xlib with module net.maxon.drawport_functioncache
drawport_general.module.xlib with module net.maxon.drawport_general
drawport_metal.module.xlib with module net.maxon.drawport_metal
drawport_selector.module.xlib with module net.maxon.drawport_selector
embree.module.xlib with module net.maxon.embree
geom.module.xlib with module net.maxon.geom
geometry_abstraction.module.xlib with module net.maxon.geometry_abstraction
image_openexr.module.xlib with module net.maxon.image_openexr
licensing.module.xlib with module net.maxon.licensing
magicbulletlooks.module.xlib with module net.maxon.magicbulletlooks
math.module.xlib with module net.maxon.math
mesh.module.xlib with module net.maxon.mesh
misc.module.xlib with module net.maxon.misc
mvp_base_presenter.module.xlib with module net.maxon.mvp_base_presenter
mvp_base_view.module.xlib with module net.maxon.mvp_base_view
mvp_gluon.module.xlib with module net.maxon.mvp_gluon
mvp_nodegraph_presenters.module.xlib with module net.maxon.mvp_nodegraph_presenters
mvp_nodegraph_widgets.module.xlib with module net.maxon.mvp_nodegraph_widgets
mvp_nodes_presenters.module.xlib with module net.maxon.mvp_nodes_presenters
mvp_widgets.module.xlib with module net.maxon.mvp_widgets
network.module.xlib with module net.maxon.network
neutron.module.xlib with module net.maxon.neutron
nodes.module.xlib with module net.maxon.nodes
nodes_corenodes.module.xlib with module net.maxon.nodes_corenodes
opensubdiv.module.xlib with module net.maxon.opensubdiv
physx.module.xlib with module net.maxon.physx
placement.module.xlib with module net.maxon.placement
post.module.xlib with module net.maxon.post
pythonconfig.module.xlib with module net.maxon.pythonconfig
pythonvm.module.xlib with module net.maxon.pythonvm
reflection.module.xlib with module net.maxon.reflection
render.module.xlib with module net.maxon.render
retargetbase.module.xlib with module net.maxon.retargetbase
scene_abstraction.module.xlib with module net.maxon.scene_abstraction
shaderbase.module.xlib with module net.maxon.shaderbase
shadernodes.module.xlib with module net.maxon.shadernodes
svg.module.xlib with module net.maxon.svg
tessellation.module.xlib with module net.maxon.tessellation
tool_system.module.xlib with module net.maxon.tool_system
usd.module.xlib with module net.maxon.usd
vhacd.module.xlib with module net.maxon.vhacd
cadexchangeconfig.xlib with module net.maxon.c4d.cadexchangeconfig
substanceconfig.xlib with module net.maxon.c4d.substanceconfig
addons.xlib with module net.maxon.c4d.addons
advanced_render.xlib with module net.maxon.c4d.advanced_render
alembic.xlib with module net.maxon.c4d.alembic
archigrass.xlib with module net.maxon.c4d.archigrass
assetbrowser.xlib with module net.maxon.c4d.assetbrowser
bitmapfilter.xlib with module net.maxon.c4d.bitmapfilter
bpexchange.xlib with module net.maxon.c4d.bpexchange
browser.xlib with module net.maxon.c4d.browser
bugslife_client.xlib with module net.maxon.c4d.bugslife_client
c4d_emulation.xlib with module net.maxon.c4d.c4d_emulation
c4d_viewport_render.xlib with module net.maxon.c4d.c4d_viewport_render
WARNING: Error loading file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4doctane/c4doctane-R25.xlib: Could not load dll. Error code: dlopen(/Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4doctane/c4doctane-R25.xlib, 0x0006): tried: '/Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4doctane/c4doctane-R25.xlib' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e')), '/usr/local/lib/c4doctane-R25.xlib' (no such file), '/usr/lib/c4doctane-R25.xlib' (no such file). (file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4doctane/c4doctane-R25.xlib) [osx_dll.cpp(88)] [general.cpp(445)]
WARNING: Error loading file:///Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/c4doctane-R25.xlib: Could not load dll. Error code: dlopen(/Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/c4doctane-R25.xlib, 0x0006): tried: '/Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/c4doctane-R25.xlib' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e')), '/usr/local/lib/c4doctane-R25.xlib' (no such file), '/usr/lib/c4doctane-R25.xlib' (no such file). (file:///Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/c4doctane-R25.xlib) [osx_dll.cpp(88)] [general.cpp(445)]
ca.xlib with module net.maxon.c4d.ca
ca2.xlib with module net.maxon.c4d.ca2
cadexchange.xlib with module net.maxon.c4d.cadexchange
clothilde.xlib with module net.maxon.c4d.clothilde
collada14.xlib with module net.maxon.c4d.collada14
collada15.xlib with module net.maxon.c4d.collada15
colorchoosergui.xlib with module net.maxon.c4d.colorchoosergui
compositing.xlib with module net.maxon.c4d.compositing
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Cyc Types:
cyctypes.xlib with module com.greyscalegorilla.cyctypes
deltamush.xlib with module net.maxon.c4d.deltamush
deployment.xlib with module net.maxon.c4d.deployment
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/DropZone:
dropzone.xlib with module com.greyscalegorilla.dropzone
dwg.xlib with module net.maxon.c4d.dwg
dwgobjects.xlib with module net.maxon.c4d.dwgobjects
dynamics.xlib with module net.maxon.c4d.dynamics
exchanges.xlib with module net.maxon.c4d.exchanges
expressiontag.xlib with module net.maxon.c4d.expressiontag
fbx.xlib with module net.maxon.c4d.fbx
gltf.xlib with module net.maxon.c4d.gltf
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/GorillaCam:
gorillacam.xlib with module com.greyscalegorilla.gorillacam
goz.xlib with module net.maxon.c4d.goz
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/osx_r25_greyscalegorillahub:
greyscalegorillahub.xlib with module com.greyscalegorilla.greyscalegorillahub
hair.xlib with module net.maxon.c4d.hair
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/HDRI Link:
hdrilink.xlib with module com.greyscalegorilla.hdrilink
i_skp.xlib with module net.maxon.c4d.i_skp
interop.xlib with module net.maxon.c4d.interop
interop_forger.xlib with module net.maxon.c4d.interop_forger
io_forger.xlib with module net.maxon.c4d.io_forger
io_obj.xlib with module net.maxon.c4d.io_obj
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Light Kit Pro:
lightkit3.xlib with module com.greyscalegorilla.lightkit3
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Light Types:
lighttypes.xlib with module com.greyscalegorilla.lighttypes
metrics.xlib with module net.maxon.c4d.metrics
mkmodeler.xlib with module net.maxon.c4d.mkmodeler
mocca.xlib with module net.maxon.c4d.mocca
model.xlib with module net.maxon.c4d.model
mograph.xlib with module net.maxon.c4d.mograph
motioncam.xlib with module net.maxon.c4d.motioncam
motiontracker.xlib with module net.maxon.c4d.motiontracker
nbo.xlib with module net.maxon.c4d.nbo
nbp.xlib with module net.maxon.c4d.nbp
newman.xlib with module net.maxon.c4d.newman
nodeeditor.xlib with module net.maxon.c4d.nodeeditor
objects.xlib with module net.maxon.c4d.objects
onlineupdater.xlib with module net.maxon.c4d.onlineupdater
physx_hybrid.xlib with module net.maxon.c4d.physx_hybrid
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/PlusLibrary:
pluslibrary.xlib with module com.greyscalegorilla.pluslibrary
projectassetinspector.xlib with module net.maxon.c4d.projectassetinspector
python.xlib with module net.maxon.c4d.python
redshift.xlib with module net.maxon.c4d.redshift
relaxuv.xlib with module net.maxon.c4d.relaxuv
scenemanager2.xlib with module net.maxon.c4d.scenemanager2
sculpt.xlib with module net.maxon.c4d.sculpt
sculptbrushes.xlib with module net.maxon.c4d.sculptbrushes
shader.xlib with module net.maxon.c4d.shader
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Signal:
signal.xlib with module com.greyscalegorilla.signal
sketch.xlib with module net.maxon.c4d.sketch
sky.xlib with module net.maxon.c4d.sky
sla.xlib with module net.maxon.c4d.sla
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Social Frame:
socialframe.xlib with module com.greyscalegorilla.socialframe
spacemouse.xlib with module net.maxon.c4d.spacemouse
teamrender.xlib with module net.maxon.c4d.teamrender
thinking_particles.xlib with module net.maxon.c4d.thinking_particles
tool_system_hybrid.xlib with module net.maxon.c4d.tool_system_hybrid
Loading from directory file:///Users/ptharan/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/Greyscalegorilla/Topcoat:
topcoat.xlib with module com.greyscalegorilla.topcoat
tpoperators.xlib with module net.maxon.c4d.tpoperators
usd.xlib with module net.maxon.c4d.usd
uvviewport.xlib with module net.maxon.c4d.uvviewport
volumes.xlib with module net.maxon.c4d.volumes
xpressocore.xlib with module net.maxon.c4d.xpressocore
xtensions.xlib with module net.maxon.c4d.xtensions
Drawport API initialized
Framework : Metal
Vendor : Apple
Device : Apple M1 Max
Framework version: 2.2
Driver version : 2.2
HDRI Studio Rig V(2.153) - for R23+
Quixel Bridge Plugin::Error Line : 67 OSError [Errno 48] Address already in use
GeOutString: Several plugins used in this project are missing.
Saving may cause loss of plugin data!
Plugin 'Octane Renderer' (ID 1029525)
Plugin 'OctaneCameraTag' (ID 1029524)
Plugin 'Texture Projection' (ID 1031460)
Plugin 'Transform' (ID 1030961)
Plugin 'Octane ObjectTag' (ID 1029603)
GeOutString: This project is already open.
Do you want to open it with the same name and title?
=== RestartMovesService from MessageResult(GetAppVersionInfo* message)
AioServiceWorkerThread terminated.
Not sure what this is all about as it's loading properly in cinema4d, it's just when I go to export the ORBX using the terminal it keeps saying Quixel Bridge is not working. Please share if this anything I can do
don't know about Quixel sorry, but, since you are working on an Apple M1 chip, there is an error in the log, because Cinema 4D.app is loaded in native mode, so c4doctaneX plugin cannot work:
To run Cinema 4D.app in Rosetta mode in the Terminal, you need to firstly enter arch -x86_64, then hit the space bar, then add the classic format with the Cinema 4D path, the .c4d file path, -nogui, -exportORBX, and filnally the destination path.
ciao,
Beppe
Return to “The Render Network”
