Render error
scratch33
I have some issues upgrading de nvidia drivers.
If I update to the latest drivers, octane give me some random render failures.
For example, drivers 440.97 and 441.08 don't works well.
417.22 works just fine.
I use a titan black coupled to a 1080 ti.
The real problem is that other softwares need last drivers to works.
Is this a know issue.
Can this be adressed?
Here is an example of error(not always the same) :
OCTANE API MSG: CUDA error 2 on device 1: out of memory
00:07:45 (0465.94) * OCTANE API MSG: -> failed to pin memory
00:07:45 (0465.94) * OCTANE API MSG: device 1: failed to pin film buffer
00:07:45 (0465.94) |
00:07:45 (0465.94) | ++++++++++++++++++++++++++
00:07:45 (0465.94) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:07:45 (0465.94) | IPR: reset image callback
00:07:45 (0465.94) | IPR: wait for the getPreviewImage function
00:07:45 (0466.00) | IPR: redrawRendering command
00:07:45 (0466.00) | IPR: set IPR camera options
00:07:45 (0466.00) | Update and continue rendering scene
00:07:45 (0466.00) | Updating rendering scene
00:07:45 (0466.00) | Scene updated
00:07:46 (0466.01) | IPR: redrawRendering command
00:07:46 (0466.01) | IPR: set IPR camera options
00:07:46 (0466.01) | Update and continue rendering scene
00:07:46 (0466.01) | Updating rendering scene
00:07:46 (0466.01) | Scene updated
00:07:46 (0466.03) | IPR: redrawRendering command
00:07:46 (0466.03) | IPR: set IPR camera options
00:07:46 (0466.03) | Update and continue rendering scene
00:07:46 (0466.03) | Updating rendering scene
00:07:46 (0466.03) | Scene updated
00:07:46 (0466.04) | IPR: redrawRendering command
00:07:46 (0466.04) | IPR: free the OpenGL buffers
00:07:46 (0466.04) | IPR: set IPR camera options
00:07:46 (0466.04) | Update and continue rendering scene
00:07:46 (0466.04) | Updating rendering scene
00:07:46 (0466.04) | Scene updated
00:07:46 (0466.04) | IPR: rendering done
00:07:46 (0466.05) | IPR: redrawRendering command
00:07:46 (0466.05) | IPR: set IPR camera options
00:07:46 (0466.05) | Update and continue rendering scene
00:07:46 (0466.05) | Updating rendering scene
00:07:46 (0466.05) | Scene updated
00:07:46 (0466.06) | IPR: redrawRendering command
00:07:46 (0466.06) | IPR: set IPR camera options
00:07:46 (0466.06) | Update and continue rendering scene
00:07:46 (0466.06) | Updating rendering scene
00:07:46 (0466.06) | Scene updated
00:07:46 (0466.07) | IPR: redrawRendering command
00:07:46 (0466.07) | IPR: set IPR camera options
00:07:46 (0466.07) | Update and continue rendering scene
00:07:46 (0466.07) | Updating rendering scene
00:07:46 (0466.07) | Scene updated
00:07:46 (0466.13) * OCTANE API MSG: CUDA error 2 on device 0: out of memory
00:07:46 (0466.13) * OCTANE API MSG: -> failed to pin memory
00:07:46 (0466.13) * OCTANE API MSG: device 0: failed to pin film buffer
hkleton
Do you use the gameready driver or the studio driver?
My problems with Octane went away when I switched TO Studiodrivers.
scratch33
I use game ready drivers because the studio drivers are not compatible with titan black GC.
LightwaveGuru
scratch33 wrote:Hi,
same errors here with Titan X (maxwell chips) and the actuell nvidia driver.
BUT!
if you not use the DENOISER the Problem is gone....its CRAZY :)
snip LWGURU
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
mikefrisk
Is that with denoise on completion? Gets very crashy for me if it denoises during render.
LightwaveGuru
mikefrisk wrote:Is that with denoise on completion?
YES!
snip lwguru
Return to “Lightwave 3D”
