OctaneRender 2019 for Modo [OBSOLETE]
funk
Thanks Paul. I noticed you updated the original post with a new build
2019.1.5.159 (04-Mar-2020)
- Fixed a number of small issues introduced in release 158
- Revised the render status window to only show relevant information, and also provide details for when render region is on
Can you please make sure to add a new post to this thread when you do that? That way, anyone subscribed to this thread gets a notification email.
Hesekiel2517
Hey there i want to use Modos Fur and a vertexmap at the same time. Building the Shader Works finde. But when i enable Modo Render Cache the Vertexmap stops to work. Is there a way around this?
Hesekiel2517 wrote:Hey there i want to use Modos Fur and a vertexmap at the same time. Building the Shader Works finde. But when i enable Modo Render Cache the Vertexmap stops to work. Is there a way around this?
Can you sent a scene which demonstrates this issue, and I can take a closer look.
Hesekiel2517
Rendecache On
Rendercache Off
Here you are. VMaps don't work if the rendercache is enabled
Rendercache_VMap.zip
(11.29 KiB) Downloaded 932 times
Thanks for providing the scene. I can now confirm that unfortunately the Modo Render Cache does not provide Vertex Map textures or weights. I suggest submitting a Feature Request to Foundry for the to add this.
Return to “Foundry Modo”
