OctaneRender 2018 for Modo [OBSOLETE]
I have updated the WINDOWS installers at the top of this thread with:
2018.1.3.145
- Compiled with Octane 2018.1.3
- Fixed error where changing a color property from an item that was not a material (ie. the white balance) was not live updating the Octane viewport
- Fixed "Mesh not present in mesh item map when adding to mesh container" displaying when using the octane.saveAnimation command on a scene with a blank mesh used as an instance source
- Moving the Modo Camera via the OpenGL viewport now live-updates in the Octane Viewport
funk
face_off wrote: - Moving the Modo Camera via the OpenGL viewport now live-updates in the Octane Viewport
It's so nice to finally have live camera updates. The last few releases have been really awesome too.
Thanks Paul!
Tharso
face_off wrote:
7000 px with a simple box? Impossible. AMD 1950x 1x1080ti 2x 1070 and 32gb memory.
edit: working with one 8k texture
Once you get to rendering at 7k x 7k, a huge amount of memory is needed - and denoising this size image takes even more memory. I suggest trying different OOC settings to find the right balance between GPU RAM and CPU RAM. You could also export the scene to ORBX and render it in Octane Standalone, which doesn't have the overhead of having Modo in memory.
And crash modo is the best action to achieve when I reach this limit? :|
I just started Modo12, added a cube, set the Octane resolution to 7k x 7k, enabled denoising in the Imager settings, set the max samples to 10, and the render completed to the point of denoising, then I got an Octane error ("out of memory") and there was no crash. I have 16GB of RAM and 4GB VRAM. OOC was not enabled. I tried with OOC enabled and got the same result. So I cannot replicate the crash you are getting, sorry. I you send me the 8k texture you are using, I can try with that.
Tharso
Ok Thx. I will send to you
I have posted an EXPERIMENTAL build of the Octane 2019.1 XB2 version of the plugin at viewforum.php?f=34
Hesekiel2517
Thank you very much, but the link does not work for me
Try viewtopic.php?f=34&t=71990.
Hesekiel2517
Nevermind, i was in the wrong forum and thought there is a new build with 2019.2 XB1. Sorry about that
This version of the plugin is now obsolete, and replaced with viewtopic.php?f=34&t=71990.
Return to “Foundry Modo”
