1.2.0.1370
Moderator: ChrisHekman
ChrisHekman
Features
  • Upgraded to Octane 2018.1
  • C# API - User can now access various parts of the plugin via C# (Experimental)
Fixes
  • Fixed one cause for the "Did not receive available versions from server" error
  • Fixed plugin downloading issue when using Unity 2018 / .Net 4.0
  • Fixed issue with Override Materials losing connection to texture when texture is moved from one asset folder to another
  • ORBX unpacking now correctly copies texture settings
  • Removed "Updating Rendertarget" debug message
  • Added unity meta files for runtime.dll and Baking Shader
liujialin_art
License login expired, Unity program crashed
ChrisHekman
liujialin_art wrote:License login expired, Unity program crashed
Im sorry to hear that. Could you give me the License Login Expired error message? And if possible, your unity account details?
Sergey91
Hey guys! Had the same issue with licensing. How this can be fixed?
ChrisHekman
Sergey91 wrote:Hey guys! Had the same issue with licensing. How this can be fixed?
Hi Sergey,
This license issue should be fixed. Can you confirm?
oktomus
ChrisHekman wrote:Features
[*]C# API - User can now access various parts of the plugin via C# (Experimental)[/list]
I want to try this! Where can I find informations about it ?
ChrisHekman
There is no documentation atm.
The basic setup is that you can now access Octane components and set their settings via C#.
PBRInstanceProperties, PBRTerrainComponent, PBRRenderTargetComponent are exposed.
PBRRenderTargetComponent can return its Rendertarget member variable which contains the settings for it.
RenderTarget is derived from the Node class, which is how you can set various settings.
If you want to see what can be set and get from the rendertarget node, you can open the OctaneGUI and rightclick on a rendertarget node and press "Show in lua api browser"
Sergey91
Hi Chris! Everything works well now. Thanks for fixing!
ChrisHekman
Sergey91 wrote:Hi Chris! Everything works well now. Thanks for fixing!
Great to hear!
oktomus
ChrisHekman wrote:
oktomus wrote:
ChrisHekman wrote: If you want to see what can be set and get from the rendertarget node, you can open the OctaneGUI and rightclick on a rendertarget node and press "Show in lua api browser"
Nice :D Thanks !
Return to “Unity”
