Hi Juanjo,
I've recently switched to ubuntu, I have Redshift and Arnold installed and working. Octane comes up in the shelf tool but gives ma a python issue similar to other errors I got when version numbers on Arnold were wrong.
I have Octane standalone installed and working.
Could you look at what I may be doing wrong?
Houdini 16.0.557
ENV:
HOUDINI_PATH = "/usr/redshift/redshift4houdini/16.0.557;/home/bronic/Octane_3.06.0.4_Houdini_16.0.557_Linux_gcc4.8;/home/bronic/htoa/htoa-1.14.4_r987f7af_houdini-16.0.557/htoa-1.14.4_r987f7af_houdini-${HOUDINI_VERSION};&"
PATH = "/usr/redshift/bin:$PATH/bin:$PATH"
HOUDINI_DSO_ERROR = 2
Linux Install issue
What Ubuntu version are you using? I think that the latest one doesn't have the freeglut lib used by the plugin installed by default. Can you please try this on your terminal?
sudo apt-get install freeglut3-dev
If this doesn't work, perhaps the problem is related to your PATH variable. You could try to include the plugin "bin" folder on it, something like:
PATH = "/usr/redshift/bin:$PATH/bin:/home/bronic/Octane_3.06.0.4_Houdini_16.0.557_Linux_gcc4.8/bin:$PATH"
Hello, I have same issue but on Centos 7
here is my variable and I have houdini 16.557 and 16.583 installed but no luck..
HOUDINI_PATH = /home/dominik/Soft/Octane_3.06.0.0_TEST2_Houdini_Linux/Octane_3.06.0.0_Houdini_16.0.504.20_Linux_gcc4.8;&
Houdini doesn't load when this variable is set.
The 16.0.504.20 plugin build is not going to work with H16.0.583. You must use the 16.0.557 plugin build. Your HOUDINI_PATH variable should be something like this (if you have the plugin folder inside the "Soft" folder):
HOUDINI_PATH = "home/dominik/Soft/Octane_3.06.0.4_Houdini_16.0.557_Linux_gcc4.8;&"
