Yoyoz - belated happy birthday!
Got the following error and am stumped. Um, help?
location:/opt/blender25_r_r35537/2.56/scripts/modules/bpy/ops.py:179
Octane plug-in v1.09 on 2.56.3.35537 : Rendering still image
Octane plug-in v1.09 on 2.56.3.35537 : Output ocs: "/home/dani/tests/test.ocs"
Octane plug-in v1.09 on 2.56.3.35537 : Output obj: "/home/dani/tests/test.obj"
Octane plug-in v1.09 on 2.56.3.35537 : Output mtl: "/home/dani/tests/test.mtl"
Octane plug-in v1.09 on 2.56.3.35537 : Unit Factor (rescaling): 1.0000
Octane plug-in v1.09 on 2.56.3.35537 : Exporting frame #1
Octane plug-in v1.09 on 2.56.3.35537 : Begin OBJ/MTL export
Octane plug-in v1.09 on 2.56.3.35537 : OBJ file: "/home/dani/tests/test.obj.temp"
Traceback (most recent call last):
File "/opt/blender25_r_r35537/2.56/scripts/addons/octanerender/engine.py", line 97, in render
mtl_list = write_obj(objTemp, mtlFile, obj_list, scene, unitFactor)
File "/opt/blender25_r_r35537/2.56/scripts/addons/octanerender/export.py", line 386, in write_obj
me = ob.create_mesh(scene, EXPORT_APPLY_MODIFIERS, 'RENDER')
AttributeError: 'Object' object has no attribute 'create_mesh'
Plugin v1.09 AttributeError error
Hi Dani,
this is due to an API change that happened yesterday and affects only builds available since this morning. I'll publish a packaged update tomorrow but you can do the following in the meantime:
- edit export.py
- go to line 386
- replace 'create_mesh' with 'to_mesh'
Be carefull not to alter indentation when doing the modification.
Lionel
PS: thanks!
- edit export.py
- go to line 386
Lionel
PS: thanks!
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
Yoyoz, do you ever sleep?
I have no idea how you manage to keep pace with the changes in the API. Your dedication, however, is deeply appreciated; a sentiment which I'm sure every Blender head Octane user would echo.
Awesome stuff. Thanks a million, and more power to your elbow!
Ubuntu 11.04, Q6600 2.4GHz 4-core, 4GB RAM, 8800GT & GTX 460 2GB, Blender 2.59, Octane 2.51
I did try to see if I could find what was wrong. I couldn't see anything obvious.
Roll on 2.57. At least the API might stabilise then.
(OS) Windows 7(64)
(OS) Windows 7(64)
I duly modified the file as instructed, and everything ran hunky dory until the console spat this out:
Cheers.
Octane plug-in v1.09 on 2.56.3.35537 : Creating dupli_list on <dining table>
File "/opt/blender25_r_r35537/2.56/scripts/addons/octanerender/export.py", line 372, in write_obj
ob_main.create_dupli_list(scene)
AttributeError: 'Object' object has no attribute 'create_dupli_list'
location:/opt/blender25_r_r35537/2.56/scripts/modules/bpy/ops.py:179Ubuntu 11.04, Q6600 2.4GHz 4-core, 4GB RAM, 8800GT & GTX 460 2GB, Blender 2.59, Octane 2.51
This is same story again... (they're really turning me crazy...)
It should be OK if you do the following:
- go to line 372 of export.py and replace 'create_dupli_list' with 'dupli_list_create'
- in same file, line 702, replace 'free_dupli_list' with 'dupli_list_clear'
Please let me know if it works so I can package the update.
Lionel
Lionel
- mib2berlin
Hi, test your changes and work with Rev: 35575.
THX, mib
THX, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
I am really sorry for the delay - my only excuse being that I am crazy busy at the moment, which always helps.
Just to confirm, your most recent edit works a charm.
How you stay sane with the constant changing and chopping of the API shall presumably remain a mystery.
Many thanks, and cheers!
Who said I was still sane?
I offer my humblest apologies for making such an unwarranted assumption, and will endeavour to refrain from repeating the offence.
Do we, by some splendid coincidence, share hatters?
