wet reflective Surface
Sinelab01
I would like to create a ground surface with different levels of reflectiveness like it had been raining how would I go about this ? thanks in advance
juanjgon
Mixing two materials (one wet and one dry) using the material mixer? You can use a procedural or an additional texture map to control the materials mixing pattern.
Sinelab01
Thanks for the reply, sorry a little confused, so I could use say an black and white would I connect that to the material mixer ?
juanjgon
Yes, in this case I'm using a procedural, but you can use also a texture image as mask.
Sinelab01
Wow Thanks Juanjo for your help this is awesome, thank you !
Return to “Lightwave 3D”
