Is it possible to blur the environment (or any texture)?
atnreg
Hi!
In 3D-Coat it is possible to blur any environment map in realtime and that gives great results. So I am wondering, is it possible to do the same in OctaneLW? I think that if there is way to blur any image texture, then it works for EXR maps too but I could not find any solution to that in forum or manual :o
Is there some trick to do that? Maybe using DOF but it slows down too much and is overkill for normal renders so if just the environment map was blurred, it would give great lighting possibilities. And I mean adjustable blur, not some blur made outside Octane/LW.
Anyone any ideas? :)
Thank you very much in advance!
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
Terryvfx
Sadly no, there is no blur node the only way to deal with this in a good way is to do the blurring before hand in something like Photoshop :(
juanjgon
Sorry, currently Octane doesn't have a texture map blur tool. You need to blur your texture using a external tool.
atnreg
Ok, that's what I was afraid of but thank you for confirming that so I don't think I've missed something :)
Possible future feature idea? ;)
It would be great to be able to blur the textures on the fly, it would provide great effects for various needs.
Antti
OlaHaldor
Just an idea for a workaround. Not tested, so don't take my word for it whether it works.
Make a globe with a blurred version of the BG image.. Won't that work ?
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
atnreg
OlaHaldor wrote:Just an idea for a workaround. Not tested, so don't take my word for it whether it works.
Hmm...I'm not sure if I got your idea, of course I could blur the env map in Photoshop and use that (what is the difference for making globe separately?) but I would like to have adjustable blur.
Your idea may be something great but please can you explain more? :)
Thanks!
Antti
OlaHaldor
I forgot to deactivate Octane at work, and unlocking through the License panel doesn't work (damn you new V3 licensing!!...) so I cannot test it during the weekend. :x
The idea was: if the image you use to light the scene have some specific details that adds some detail to the lighting you're going to lose that if you blur the image.
So using an untouched, rich with details, to light the scene - and use the blurred image as the image that will be seen in the background.
Might not make sense, but it's the only thing I can imagine possible in a simple render.
If you're up for some extra work, you could render the background and geometry separate and comp after and blur as much as you like. Render layers or passes, and you're good to go.
atnreg
OlaHaldor wrote:I forgot to deactivate Octane at work, and unlocking through the License panel doesn't work (damn you new V3 licensing!!...) so I cannot test it during the weekend. :x
Thank you yes now I got it :)
The idea probably works but I would like the blur to be adjustable so only way would be to make several blur amounts versions of the original and then use those. But with that work, I can make the normal env map like that :)
But your idea is great (and actually how 3D-Coat does it) as the reflections will be sharp but the background still blurred :)
So thank you very much!
Antti
Lewis
Have you tried to use Full precision Blur in Image editor ? Maybe that will make Octane see blurry version of HDRI also ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
atnreg
Lewis wrote:Have you tried to use Full precision Blur in Image editor ? Maybe that will make Octane see blurry version of HDRI also ?
Sadly Octane does not care a bit about Image Editor settings, it reads the images directly so this does not work either :(
Thanks for the tip anyway :)
Antti
Return to “Lightwave 3D”
