Hi, I am trying to vary the uv projection transforms in an octane shader , using the "procedural random color" node. I can see the effect of that node if I plug it in the diffuse color for example, I see a different shade of grey for every instance. But I see no effect if I plug it in a transform3D node, to try and vary the uv projection across instances.
And I don't know if it's a bug or what : the Octane vop "Transform3D" node input parameters are all floats, which doesn't really make sens.
Does anybody have a little tip for me ?
instances uv transform variations
Hmm, the problem is that the random color node output type is a Octane texture, that only can be linked to texture inputs, like the inputs in the materials or in the gradient node. You can't link a texture output to the float inputs of the transformation node, and I am afraid that currently Octane doesn't have a node to convert a texture to a vector float. You have the same limitation in the Standalone or in the other plugins.
Let me think about it, perhaps also other user could find a workaround to drive the UV offset using the random color node.
thank you for your answer juanjgon.
Is there any hope to see some "type conversion" nodes in the near future ? Or any way to use custom attributes ?
I would love to be able to take a little more advantage of houdini's abilities in terms of geometry attributes.
Windows 10 |NVIDIA RTX TITAN - 24GB| i9-9900K | 64GB RAM
