Swarm of flies
Carrara (Integrated Plugin developed by Sighman)
tschwenke
I need to create a swarm of flies that move. I use a standard Carrara replicator to replicate the fly. Updates fine in Carrara, but Octane does not render it. I have to click the rebuild button, then Octane updates and renders fine the movement of the original fly. (FYI: The original fly moves, but not the replicated ones.) Any ideas?
I use Octane 2.25.0086.
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Sighman
I don't see an issue in 2.25.0.88.
anim.zip
animated replicator test
(3.32 KiB) Downloaded 446 times
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
protovu
Hi Thomas,
Have you looked into Pycloid? It can be a little quirky, but it might do what you are after.
Rick
tschwenke
Thank you Sighman, but that's not the way I want to have it. I've attached a new version of yours. Animating the replicator isn't what I need, because that way, all the objects go in the SAME DIRECTION. However, I just need to animate the ORIGINAL object. Then, I can create a swarm that goes around crazy :)
Please see the file attached.
@protovu
Thank you. I know it, but I think, that pySwarm needs real objects and cannot replicate the objects. I can only create max 4 REAL objects and then replicate them to approx. 2000 objects. However, if I create 2000 REAL instances, this will be impossible to do.
Best wishes,
Thomas
Sighman
tschwenke wrote:Hi,
Please see the file
You forgot to attach the file. (Make sure you zip it first. You cannot attach .car files directly.)
tschwenke
Oh, what a mistake. Here is the link :)
https://www.dropbox.com/s/fe5u9m6c2s5r8q4/anim-v2.car
Sighman
??? The only thing I see keyframed here is the sphere. What do you expect to see happen?
tschwenke
Open the file in Carrara, then open the Octane Render Window. Go to frame 24 and see the sphere move. Now click the "Rebuild Scene" button in the Octane Render window and see the magic happen :)
Is it clear now?
Best wishes,
Thomas
Sighman
Ok, I see what you mean. I'll see what I can do, but I really don't see the difference between animating the sphere and animating the replication object.
tschwenke
I see, but please see here. I created a sphere moving around. It would impossible to create by moving the replicator itself :)
https://www.dropbox.com/s/l7xe4iswbmnxxm1/Sample.avi
Best wishes,
Thomas
Return to “Carrara”
