Motion blur amount?
coilbook
Hi Does anyone know how much motion blur I need to give to a moving object? Let's say 1080 wide and it takes an object ten seconds to move from left to right
What is the proper amount of MB ? I wish octane had auto MB option that gives correct MB amount
PS Just cannot get rid of choppy horizontal movement/judder with or without MB
Thank you
profbetis
This is mostly an artistic decision and there's no right or wrong answer. A motion blur amount of 1.0 means all motion during the frame will be captured/averaged for the blur. This is equivalent to a shutter speed of 1/24 if you're shooting at 24fps. Sometimes this is too blurry, so a good starting point would be 0.5, where half the motion is captured, giving you a good balance between sharpness and fluidity.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
coilbook
profbetis wrote:This is mostly an artistic decision and there's no right or wrong answer. A motion blur amount of 1.0 means all motion during the frame will be captured/averaged for the blur. This is equivalent to a shutter speed of 1/24 if you're shooting at 24fps. Sometimes this is too blurry, so a good starting point would be 0.5, where half the motion is captured, giving you a good balance between sharpness and fluidity.
Thank you!
Return to “Autodesk 3Ds Max”
