OctaneRender 3 for Inventor [OBSOLETE]
Autodesk Inventor (Integrated Plugin developed by Paul Kinnane)
I have refreshed the installer at the top of this thread with:
2.24.1.12
- Compiled with Octane 2.24.1
2.24.2.12
- Compiled with Octane 2.24.2
I have refreshed the installers at the top of this thread with:
3.0.1.13
- Compiled with Octane 3.0.1 (Octane 3 alpha 2)
- Added Medium and Medium Radius to the Daylight and Texture Environment settings
- Added new Render Passes
- Removed "Ambient" and "Sample Environment" GI Modes from the Direct Light kernel
- Added Deep Image settings to the kernel settings
- Added Baking Camera. The Baking Group Id's cannot be set - so you will need to only render the geometry you want to bake texturemaps for
As this is the first build of the Inventor plugin with Octane 3, pls take a backup of files prior to using them for testing this release.
3.0.6.13
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
3.0.10.14
- Compiled with Octane 3 alpha 10 (3.0.10). This means that Render Region is working again, plus many other changes (refer to the Octane Standalone 3 Alpha 10 thread for details)
- Username and password is now not entered or stored in the authentication panel
- Visible Environment pin added to the Rendertarget
I have updated the installers at the top of this thread with:
3.0.20.15
- Compiled with Octane 3.0 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
- "Int" nodes can no longer be converted to "Int Resolution" nodes
You will need an Octane 3.0 license in order to use this version of the plugin.
I have updated the installer at the top of this thread with:
3.1.1.16
- Compiled with Octane 3.01.1
- The Maximum value of the Power of Image maps for Bump maps is now 10
- You can now disconnect the Medium from the Environment Medium pin
- Added new authentication settings window which can be used to activate, and de-activate the plugin
3.2.0.16
- Compiled with Octane 3.02
3.3.3.16
- Compiled with Octane 3.03.3
3.3.4.16
- Compiled with Octane 3.03.4
Return to “Autodesk Inventor”
