Hi folks,
Not sure if this has been asked before. I searched and came up blank so here it goes.
I'm sure some of you noticed that on the stand alone (C4D also has these, not sure about the rest) all parameters have defined ranges. Some of those are obvious while some are not so obvious. It would be really great if we had something similar, tho I'm not sure if LW allows for this functionality? Thanks.
Display range for Octane node parameters ...
- UnCommonGrafx
I'm betting you won't get many +1s for this: discussions have revealed some users want that and that others often go outside those numbers, as it is allowed.
As a question that's been asked on the discussion, "Why do you need the software to tell you the limit, outside of it stopping at a set number?"
For conversation sake...
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
In LW the sliders have some ranges but you can type in any value. And in my opinion that is exactly great, that way you can adjust the values for very different cases, not only those that the parameter is meant for. I really hope this will not change in LW nor Octgane plugin
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
Hey guys,
Perhaps my question was a bit vague/misleading, I wasn't asking for hard coded limits I simply suggested that it might be handy if the OCTANE ranges were somehow available/displayed. Might be handy to know what the OCTANE ballpark is and when you're beyond it. I'm well aware of LW sliders and driving the values above and beyond, and as you I like them just as they are , in OCTANE tho most of that is mute when you are not in the ballpark so to speak, so a roughness of 200% (in LW) or 2.0 (in standalone if you could go that high) would have zero effect.
Sounds reasonable to me.adkkda wrote:Hey guys,
Vote for Juanjo!
Yes and I meant that those slider values could be limited to 'official' value range but as you can type any value, it would not limit the usageadkkda wrote:Hey guys,
There is an important problem in the LightWave SDK: it doesn't have floating sliders. I can add sliders with limited ranges, but only for integer values.
Anyway I think that there is a way to set a limit for the floating value if you scrub the <> button. I will see if this feature can be useful in our plugin.
Thanks Juanjo,juanjgon wrote:There is an important problem in the LightWave SDK: it doesn't have floating sliders. I can add sliders with limited ranges, but only for integer values.
I had an inkling that this is a LW SDK issue, and yes, only if you feel it would ultimately be useful.
Precisely Anttiatnreg wrote:Yes and I meant that those slider values could be limited to 'official' value range but as you can type any value, it would not limit the usage
A good example might be the scattering direction (-1 to 1) VS scattering scale (0.0001 - 10,000) as indicated by the octane stand alone.
Some might miss the fact that scattering direction can be reversed (negative dial) while for scattering scale you wouldn't really want to explore those extreme precision limits via a slider.
Anyway ... I just thought it might be a nice to have, plus it might make life easier for folks using Juanjo's other render integrations which I'm sure would have their own unique ranges.
