How to assign Octane3dsmax Maps via Maxscript
akira
Hi Mr.Karba, i'm trying to make my own material converter but was stuck at texture assignment:
$.material = diffuse_material()
Diffuse_Material:Diffuse_Material
$.material.diffuse_tex = alpha_image ()
** system exception **
$.material.diffuse_tex = copy alpha_image ()
-- Unable to convert: Alpha_Image to type: TextureMap
can you tell me if it's possible to do that?
Regards,
akira.
acc24ex
this is where I got stuck and couldn't find any way of working it out - if you assign any texture node to the shader node via maxscript gives out a system exception error.. this did work on the previous versions like octane 1.2
- also Karba mentioned somewhere that he doesn't do maxscript..
akira
So sad to hear that, the built in converter usually assign a rgb image to the opacity slot instead of an alpha image or greyscale image,
Without maxscript automation, I have to manually correct them one by one, sigh.
HHbomb
+1 more access and docs for maxscript.
Jari
I got same issue! I can only switch texture map if I first manually add texture map from material editor. Before that that .diffuse_tex is undefined and I have no idea how to change that with maxscript.
Karba
akira wrote:Hi Mr.Karba, i'm trying to make my own material converter but was stuck at texture assignment:
Regards,
akira.
Did you try to change diffuse_input_type first?
0 - float value
1 - color
2 - texture
Jari
Yes I did. Could you tell me how your material LiveDB makes the trick when you press "place to active slot of material editor"?
Karba
Jari wrote:Yes I did. Could you tell me how your material LiveDB makes the trick when you press "place to active slot of material editor"?
it is c++ code, no script
akira
Regards,
akira.
0 - float value
1 - color
2 - texture
yes, i did, and still got the same error.
as you can see the error message said that the Alpha_Image(or RGB_Image) is not the same type as TextureMap.
acc24ex
I was looking far all options for hours and tried all workarounds I could think of, frustration set in so I gave up
.. something changed from octane version 1.0 or something and after 1.5 it gave out errors, I have a feeling something in the plugin is maybe differently named, or placed under a different class or something, and only gives out this error on maxscript when trying to some assign texturemap
- maybe rgbimage noise etc aren't of the class texturemap, maybe it's named texturemap2 or something like that and it works out fine in the plugin but not here
Return to “Autodesk 3Ds Max”
