Errors in 1.55a
MaTtY631990
Hi Karba
I have ran into a couple of errors along the way in testing 1.55a release. This is pretty much the only problems with the plugin. Also included any info from the log. Movable proxy is important and saves time for animation and memory so this would great to have this working again in a new release.
1. Movable proxy does not work, processing every frame and no instancing.
Error log:
can't set empty array as animation. use clearAnim() to clear an animation.
2.
null sky texture option on Octane daylight.
Error log:
Tried to access pin via an invalid ID P_TEXTURE (151)
Tried to access null node pin
3.
Turning off alphashadows locks up computer/driver failure.Am not sure why you need to turn off this option off really since you need for a lot of things, and it is best to not touch this option anyway but I thought I would mention since it is severe bug.
Karba
Fixed
I will release a new version tomorrow
solomon
Karba wrote:Fixed
hi Karba, is there a link for the updated 1.55 download?
Solomon W. Jagwe
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
Karba
solomon wrote:
Karba wrote:Fixed
May be here? http://render.otoy.com/forum/viewforum.php?f=80
Return to “Autodesk 3Ds Max”
