I've been trying to use the mouseCallback() function which is supposedly available in the API but with no success. While the regular button and text editor component callbacks are easily handled, nothing happens with mouseCallback. Anyone know how to do this?
Much obliged
-Mtl
Lua mouseCallback() not working
- stratified
Hi Mithrandir,
I think it only works with the bitmap component. I don't remember why it doesn't work with other components (might be a bug). I will look into it. This example should work:
cheers,
Thomas
-- mouse handler example
local bitmap = octane.gui.create
type = octane.gui.componentType.BITMAP,
width = 400,
height = 200,
mouseCallback = function(component, event, x, y, sx, sy)
print(string.format("event %d @ position { %d, %d })", event, x, y))
end
local window = octane.gui.create
type = octane.gui.componentType.WINDOW,
width = 500,
height = 500,
text = "Mouse Test",
children = { bitmap },
mouseCallback = function(event, x, y)
print("this seems to be broken!")
end
window:showWindow()
Thomas
- Mithrandir
Thank you Thomas,
Certainly opens possibilities for using bitmaps. Although, if not a bug with the other components, then mouseCallback() should be removed from the documentation showing it as one of their methods.
It would be good if it worked for text editor so that action could be taken when clicking on a field. Right now, no callback action takes place until a character is entered. If mouse callbacks can't be used here, the an on_enter and on_exit callback would make coding and error handling much easier.
Again, thanks
-Mtl
Again, thanks
-Mtl
