Camera doesn't match with MB on
CANDITO
Hi there,
just did a couple of tests this weekend and noticed
that octane camera doesn't match footage when MB is on.
I did a quick auto track on syntheyes, which did a pretty job
with this shaky shot.
R2D2 object is Karl Stocker's one, cool object found on http://www.scifi3D.com
On this first shot both camera and object MB where on (50% + 4 passes for object MB)
You can clearly see R2 flying above the floor
MB OBJECT.mp4
MB object + camera
(4.21 MiB) Downloaded 4080 times
On this one only camera MB was on, it's still shaky but it's better
it's mostly on the big vertical axis changes that things don't go well
MB CAMERA.mp4
MB camera
(4.21 MiB) Downloaded 4048 times
On this one, all MB was off, and all is ok
NO MB.mp4
No MB
(4.23 MiB) Downloaded 4096 times
On this last one, it's just a basic LW render to check the camera
LW.mp4
LW
(4.12 MiB) Downloaded 4072 times
I'm using LW 11.5.1 with the last Beta
Hope this could be fixed, thanks a lot Juanjo
juanjgon
What is the frame rate of the sequence? ... I just fixed a bug that could break the MB at 24 or 30 fps.
can you please try to render the sequence with this build? ... you only need to replace the plugin file.
http://render.otoy.com/customerdownload ... 1.5_11_6.p
Anyway perhaps also the problem is the very simple shutter model supported by the plugin, that doesn't match the shutter model of your camera.
CANDITO
Hello Juanjo,
thanks for your fast answer,
framerate is 25 fps.
I'll give a try with the new build
Olivier
CANDITO
Juanjo,
is it compatible with LW 11.5?
juanjgon
CANDITO wrote:Juanjo,
Nope, this build is for 11.6 ... anyway at 25 fps your current build should works fine. Let me think about it. Perhaps you could send to me the scene to test it here.
CANDITO
i just installed my 11.6 version, thanks ;)
i was a bit lazy and never had it done right with the plugs etc...
now it's running fine, i just launch the render, it's cooking...
I will send you the files by wetransfer, on which adress can i send them?
Olivier
juanjgon
CANDITO wrote:i just installed my 11.6 version, thanks ;)
Olivier
[email protected]
mdharrington
I've had a bit of sliding in a shot recently that I passed off as bad tracking.....
But I'm not so sure...
If this is an issue...would it be affected by the default camera MB as well ?(not Multipass)
Intel i7 980, 24gig DDR3, 2x GTX 470, 1x GTX 590
mdharrington
Just did a test....
Normal camera motion blur is not an issue...seems just the multipass (which i didnt test)
CANDITO
Juan,
sorry i did not answer sooner, i was a bit busy last days,
unfortunately the last build did the same thing.
i also did a test with multipass MB but with no object moving,
and the result is the same, a sliding that looks like
the camera movement is amplified when the shot is shaky.
I just sent you all the files by wetransfer, if you can take a look
Thanks a lot
Olivier
Return to “Lightwave 3D”
