3ds max -> Octane export script
kilaD
Wrote a small export script for max since i couldnt find anything here.
Everything should work with a click of a button after setting your Octane.exe path
For now it exports the camera FOV and pos/target, maybe i`ll add more stuff later(lights etc).
Installation: Extract to max root folder and restart max, find the script in customize->category kilaD, use on toolbar/keyboard shortcut etc
Let me know if something is strange :)
Feel free to improve the script, and post it here if you do!
edit:
- new version (kilaD_Octane Export_0.42.rar)
- exports the sundirection if you have a light in the scene (use target direct or similar)
- fixed some bugs
- Disables Isoline display on turbosmooth modifiers. Works if you use 1 Turbosmooth per object
- Geometry memory usage thing
- Uses the frame size in max rendersettings
- Bugfix..
- And another..
MAX/Octane Export Script 0.42 - Exports Cam/Sundir
Fixes Turbosmooth
(67.19 KiB) Downloaded 1447 times
kilaD_Octane Export_0.31.rar
MAX/Octane Export Script 0.31 - Exports Cam/Sundir
Fixes Turbosmooth
(53.32 KiB) Downloaded 497 times
kilaD_Octane Export_0.3.rar
MAX/Octane Export Script 0.3 - Exports Cam/Sundir
(53.25 KiB) Downloaded 460 times
kilaD_Octane Export_0.25.rar
MAX/Octane Export Script 0.25
(52.87 KiB) Downloaded 571 times
Hello
simmsimaging
Thanks for sharing this. I'll give it a try later today.
b
http://www.simmsimaging.com
blog.simmsimaging.com
i7 980 24GB Ram GTX580 3GB Vista 64 Ultimate
ttaberna
Hi
Thank you so much...but I cannot get it to work
Maybe I am installing it badly
I copy folders to maxroot then open max -> customize -> Customize UI -> Category -> kilaD -> OctaneExport
Then I put the button in new toolbar and hit octaneExport but Runtime error about Export.bmp missing appears, both with first version and 0.2 version...
Any tips?
Thank you
Edited:
Same thing doing a keyboard shortcut
Rampage IV Extreme+i7 3920k+2x GTX580 3GB+2x GTX470
kilaD
Did you extract the folders in maxroot? Are the folders in the corresponding max folders?
edit: ok, i forgot something :P. download the new version
Hello
ttaberna
:D :D WOW Now it works ok
The only thingy is that I don't know haw to use the Virtual frame buffer button
kilaD
Nice :)
Press the VFB-button after octane is finished rendering,
it then loads the image into the max framebuffer, so you can save it.
Hello
BlessOd
kilaD wrote:Nice :)
nothing appears after clicking on VFB
materials are not exported (((
but it works!
waiting for the [gk] finish work on his script))
Win 7 64 | Geforce GTX260 (216 core) | Quad 6600 (3.2GHz) | 4GB
kilaD
yes i know, it uses the relinking thing. Maybe i should skip the -r and use only the [octane -m <obj>]. anybody? no? dust!
what version of max do you have? 2008?
Hello
kubo
nice work! I'm gonna test it asap, and I let you know, but just the same, thanks for the effort!
Javadevil
Looks great,
I can get it to export but it doesn't open Octane.
I've pointed the script to the octane directory too.
