error on start up
basdbas
Hi all
I just installed octane render on win7 computer with this file OctaneRender_Demo_102_beta2_win_x64 my grafics card is a NVIDIA GeForce GTX 260
but I get this error on start up
"no cuda capable devices found" but the card has cuda according to nvidia
is there a solution to this problem?
thanx
radiance
you need to install the latest drivers, check the included readme file.
Radiance
basdbas
Thanx for the quick reply
just solved the problem by installing the cuda driver :oops:
grtz
Rickyx
I've got the same problem on Linux Ubuntu 9.04.
I've the correct driver and path as Cuda drivers asks:
* Please make sure your PATH includes /usr/local/cuda/bin
* Please make sure your LD_LIBRARY_PATH
*   for 32-bit Linux distributions includes /usr/local/cuda/lib
*   for 64-bit Linux distributions includes /usr/local/cuda/lib64:/usr/local/cuda/lib
* OR
*   for 32-bit Linux distributions add /usr/local/cuda/lib
*   for 64-bit Linux distributions add /usr/local/cuda/lib64 and /usr/local/cuda/lib
* to /etc/ld.so.conf and run ldconfig as root
My driver ( cudatoolkit_3.0_linux_64_ubuntu9.04.run ) seems correctly installed:
no error during installation and CUDA-Z detect my GeForce 9800GT.
Where may the error be?
Thank you,
Rickyx.
radiance
another linux user got the same issue and he uninstalled everything, and reinstalled the latest cuda toolkit.
you need to set 'export LD_LIBRARY_PATH=$LD_LIBRARYPATH:/usr/local/cuda/lib64' in your .profile or bash profile in your home directory.
Radiance
