Hi there,picajol wrote:Hey Timmaigh.
I see oyu have Fractal Design R2 chasis.
Was thinking of getting one![]()
Would you say its a quite one?
well its definitely quieter than my previous shitty Eurocase. I cant compare it to other similar wanna-be silent cases though, as i did not try any of them. But when the computer is idle, or youre just browsing net, its very silent, i can sleep in the same room. I have 3x Fractal 12cm Silent fans inside + 2x Noctua NF14 in there btw. When i am rendering though, with both cores on the gtx590 running at full pelt, you definitely hear the fan screaming...but its still acceptable, i can stay in the room without going mad
Anyway, if you plan on getting more GPUs, take a bigger case. For a few months, i had 2x gtx460 and it was useless. They needed to be close to themselves, as i was unable to use the other PCI-express slot on my mobo, cause the PSU was in the way of the GPU heatsink. This was down to not the best mobo layout as well, but if the case was slightly bigger, or mobo mounted slightly higher above the PSU, it would fit. The upper card ended up so hot, the fan needed to run at 100 percent. It was awfully loud.
Otherwise though, its a great case. I love its minimalistic design with sharp edges, for me the best looking case alongside more expenise Lian-Lis. I only regret, there was not a white version of R2 like now R3, i would definitely get that one, it looks like a fridge
