It works!!!karu wrote: I believe you would just change the process space in the look definition from "Utility - Linear - sRGB" to "Output - sRGB".
I also changed the interpolation from "linear" to "best" (This removes the gradient bandings) (you can also change the interpolation to "nearest", I didn't find a difference between "best" and "nearest"),
interpolation: Linear
interpolation: Best or Nearest:
and "Output - sRGB" to "Output - Rec.709".
Final code for Rec.709 LUTs:
looks:
- !<Look>
name: Look name goes here
process_space: Output - Rec.709
transform: !<FileTransform> {src: lut_filename_goes_here.cube, interpolation: best}
Thank you!
