OctaneRender™ 2020.1 XB3 [superseded by 2020.1 RC1]
PolderAnimation
BorisGoreta wrote:Instances on geometry can't have motion blur, but if they are instanced on particles they can have motion blur.
How would this work? do you have an example? (In the standalone version).
And even then it would be nice to have motion blur working with geometry as well. That the whole object gets the velocity from the point that it is scatter on.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
BorisGoreta
Sorry I deleted my post about this I thought I was in the Lightwave section, I don't use Standalone.
p3taotoy
Bumping this one again
Any ideas?
Trying Mac OSX Slave XB3 now
Get this error when installing slave Daemon...
I checked the Launch Agents dir and there is no octane app in there.
Any ideas
Creating temporary launch script ...
Creating temporary launch agent ...
Copying bundle into /Applications and launch agent into /Library/LaunchAgents ...
32:177: execution error: Terminal got an error: cp: /Applications/.OctaneRender *Slave *.app: No such file or directory (1)
VVG
Moblur+ denoise Slave render Cuda error 700
viewtopic.php?p=378024#p378024
Maybe this is an STDL error?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
abstrax
p3taotoy wrote:Bumping this one again
Any ideas?
Any ideas
I think you copied the script from the DMG into the Application folder. Please don't do that. Just run the script directly from the DMG itself. It will copy a (hidden) bundle and set it up, but expects to find all that in the same directory as the install script itself.
In other words: Open the DMG file and then double-click "install daemon" to run the script.
p3taotoy
Ahhhhhhhhh.... Duh!!! That makes sense
I’ll try that... so used to dragging stuff into App folder.
Thanks for letting me know.
Peter
mojave
funk wrote:I've been trying to use Random walk on a volume and it just hides the volume.
Random walk does have "volume step length" and "ray step length" pins, so I assume it's meant to wok on volumes.
1. Load the orbx and start rendering. You'll see a cube volume.
2. Unplug the volume medium, and connect the random walk to the "cube.vdb"
The volume stops rendering
Hi funk,
This issue will be fixed in the next release. Just be aware that to use random walk is not meant to be used with volumes, to get it to work we need to approximate the result in a way that results will differ from those you will obtain when using a regular mesh.
Thank you.
