OctaneRender® for 3ds max® v3.06 - 4.33 [OBSOLETE]
paride4331
Hi acc24ex,
Your suggestion about using separate Gpu for material editor is a good idea to reduce lack, which I agree with you;
I have in the past suggested this to developers; it's something about SDK , so it can not be solved by 3ds Max developers.
A workaround could be using manual update option in 3ds Max material editor.
Regards
Paride
Goldisart
1
Goldisart
acc24ex
is equirectangular camera still not supported in 3ds max, or did I miss something?
Elvissuperstar007
I remind you do not forget to add an infinite plane! 3.06-34
octanegraff
Is this version compatible with 3DS Max 2018 yet? I am not finding any documentation stating that it is.
thank you
coilbook
Elvissuperstar007 wrote:I remind you do not forget to add an infinite plane! 3.06-34
what is an infinite plane for?
Elvissuperstar007
Support for infinite planes
You can now add up to 4 infinite planes to a scene using the new plane geometry node. The UV mapping is aligned with the X/-Z coordinate axis, but you can also apply a transformation to the object using the placement/scatter nodes. Displacement mapping does not work on infinite planes.
viewtopic.php?f=24&t=60014
coilbook
wow thank you
by the way where do i find it in 3ds max " manual says "new plane geometry node."
paride4331
@acc24ex,
Incorrect loading of the field-of-view settings in animated panoramic cameras was fixed in SDK 3.06.01
As recommended by other users you could export to SA or "keep upright" in camera setting.
Regards
Paride
