Hi Dartfrog,
it has already been previously encountered this issue in 4.30
Paride
OctaneRender® for 3ds max® v3.05 - 4.30 [OBSOLETE]
- paride4331
- paride4331
Hi DartFrog,
you can upgrade up to 4.23 (4.21 stable).
The issue is from 4.24 to 4.30, but found three weeks ago.
Regards
Paride
Regards
Paride
- paride4331
@Goldisart
You have also set ior to 1, but this is difficult to achieve if ior in vray is not 1.
Paride
Paride
Two issues
- when you still have octanerender vieport open, and you open another project, the viewport remains open, and you cannot close it - but I can open another render viewport
- all of this sometimes works, sometimes becomes unstable and buggy - did anyone experience this...
- the show background texture is still bugged out, at the very least, the viewport with the background texture has to be selected prior to opening the render window cause otherwise it doesn't show up
3dmax, zbrush, UE
//Behance profile //BOONAR
@acc24ex
I also ran into that problem with opening other projects. It's annoying but luckily fairly easy to work around. Hopefully it will be a quick fix after the new kernel is implemented.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
@ paride4331
Yes, but initially not even close work , falloff .... the properties of a meterial vray I am always surprised they are not physical - therefore I do not pay attention what IRQ
pay attention to the standard falloff - if the conversion takes place when metal objects
