Version 3.00 - R1.1 (25.05.2016)
eyeonestudio
Hi aoktar.....Thank For Release
Volume object: First volume filling method by spheres or particles. It's a very experimental and wip feature. Will be improved soon.
I have one Request.
You 'll know what Pyro-Cluster is.
I use for snow(volume). --> Pyro Cluster Sample https://vimeo.com/46344145
See My Stupid Scene(just example)
My Request is
Xparticles +Object Tag(Particle Rendering > single VDB file)
Thanks.. ;)
VOL-PYRO.zip
(81.26 KiB) Downloaded 275 times
eyeonestudio wrote:Volume object: First volume filling method by spheres or particles
What is this?
How to apply to scene?
Thanks... First release 3.0 :D
Find attached example scene(volume-anime)
It's still experimental. I'm investigating performance and method.
test rendering with volume+animated noise+spheres
https://vimeo.com/167867146
brasco
Congratulations on the release Ahmet, thanks for all the hard work!
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
brasco wrote:Congratulations on the release Ahmet, thanks for all the hard work!
cheers
brasc
Thanks for support.
Ron
SOLVED
After installing the final release and deactivating the licence via website it is working again.
Thank you Ahmet for this release! You are awesome!
Ron
Ron wrote:After installing standalone 3 my plugin licence cannot be found. With Beta 2 everything worked fine.
Cannot even deactivate my plugin licence to reactivate it after.
What can I do?
Ron
PS:
I already deleted the otoy_credentials but no success ...
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Ron wrote:SOLVED
Nice! It was not about plugins. Anyone has problems on running older(V2) versions? It doesn't run one me :(
dinf
aoktar wrote:Anyone has problems on running older(V2) versions? It doesn't run one me :(
Is starting, but I didn't start v3 on C4D so far but standalone 3 only.
After closing a v3 version the license site says "no license running", after closing a v2 license it says (able to) "deactivate". Seems to be as it should be. I'll try C4D later.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
Digitalism
Just bought my upgrade, thanks :)
Not sure if this is a C4D bug or an Octane bug, but if you have a layout saved (from before you upgraded) it says in the live viewer the old version, not the new version.
Digitalism wrote:Just bought my upgrade, thanks :)
yes big bug! Thanks for report. It's not fixable. Close/open and save to again layout.
jingles
The C4D Plugin requires inputting the license details in accounts/settings, but that area no longer has the option to do so.
What is the solution?
I tried erasing the preference file noted on the installation page. The installation is a clean install (removed 2.25, restarted, installed 3, restarted).
Showcases Octane Standalone connected, but no option in C4D plugin
