GeForce GTX Titan
gabrielefx
http://www.randomcontrol.com/arionbench
not bad the Titans benchs
glimpse
yeah, it seems of being very capable card =)
Refracty
Is it really way slower then a 690 ?
glimpse
Refracty wrote:Is it really way slower then a 690 ?
it seems out of the box yes, but it OC's =)
mbetke
Maybe Arion uses double precision and needs to be enabled?
I re-mounted the cards (it was also a good time for re-arranging some cables and cleaning dust in the case) and still temperature difference of 10° degree.
Found out it may be because I have two 24" screens plugged in card 1 and it run on 600-800mhz as soon as I do something like mouse movement.
Card 2 is doing nothing and rests on 300mhz.
Now I'm curious how far I can push them for rendering. But not sure if I should do it...I imagine I could break something i I let them render OC for a day or even longer.
PURE3D Visualisierungen
glimpse
mbetke wrote:Maybe Arion uses double precision and needs to be enabled?
I had the same situation with my two 460s - they have enough room to breath, enough airflow as I was running rig caseless =) but no mater what I've done, the temperature diff were bit more than 10C. I noticed with GPUZ that the card I was using to feed my monitor also has higher voltage..- I believe that was the reason why even if they ran the same speed one was a bit hotter - it's the same with CPU..if You overClock, use as low voltage as possible, to get system stable..otherwise 'cause of higher voltage temps might rise 'causing stability & longevity isdues in the end.
brasco
DP OFF - 2393.39
Core clock 1097Mhz
DP ON - 2139.11
Core clock 940Mhz (locked due to DP)
Looks like it's very much SP single core clock reliant :)
Curious about the 690 scores, I'm guessing there's some optimisation to follow in the drivers for Titan or maybe the 690s architecture suits Arion, it's still a beast after all.
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
mbetke
I see glimpse.
Well I don't complain. temapertures in idle are 42°C and 31°C and the noctua CPU cooler is a bit louder as GPus.
glimpse
mbetke wrote:I see glimpse.
if Your Noctua is louder.., than these Titans are really nearly silent =)
xiegenghong
TITAN looks very appealing. It would be hooked up to my X58 which is PCI-E 2.0, in a 2 x 16 lane configuration. Would this be a limiting factor?
GTX TITAN,GTX 590,GTX 580,I7 930,X58
